Toro 67: Removing Harmonic Balancer Nut
Old Sep 4, 2024 | 12:10 PM
Gauchobyte's Avatar
Very possibly a trivial question but.. When removing the harmonic balancer nut there has to be a mechanism for avoiding the engine from rotating, correct?, it look obvious to me, but the CSM do not mention it at all. if Yes to the question please advise best way to do that. Best Regards. Raul.
Old Sep 4, 2024 | 12:29 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I don't think there is anything. You need an impact wrench.
Old Sep 4, 2024 | 12:30 PM
Remove the #1 spark plug and use a length of nylon rope in the combustion chamber with the piston at TDC.
Old Sep 4, 2024 | 01:27 PM
Gauchobyte's Avatar
Glenn: Thanks, but that I do not have!
Olds64: Really?, That's a first for me!, I will try if nothing else comes across, wonder what they were thinking when they wrote the CSM!
Old Sep 4, 2024 | 02:57 PM
Actually, go 50*-60* clockwise beyond TDC of the #1 spark plug, put the nylon rope in the cylinder and then rotate the engine CCW to remove the nut. That way you're pushing against both of the valves while closed.
Old Sep 4, 2024 | 03:00 PM
redoldsman's Avatar
Jesse, I was going to question your first post since TDC would leave no room for the rope. I have heard of using the rope trick but have never done it. I would be sure and leave some rope hanging out the spark plug hole so you don't have to fish it out of the cylinder.
Old Sep 4, 2024 | 05:06 PM
tru-blue 442's Avatar
Old School Olds
You can use a breaker bar against the ground and blip the starter, have done it several times.
Don't forget to unplug the coil wire.
Old Sep 5, 2024 | 04:12 AM
BillK's Avatar
When I did the engine in my Wifes car I made a tool just for this purpose. It bolts to the damper and hits one of the brackets on the front, cant remember which one now.
Old Sep 5, 2024 | 06:29 AM
Kent Moore Tool J-8614, which is basically a long bar with the end designed to bolt to the harmonic balancer. I wasn't going to pay stupid money for one so I made my own by welding a bar to an old crank pulley. I've been using that tool since the late 1970s. Keep in mind that while an impact wrench will get the bolt off, you still need to hold the crank to properly torque it when you put it back together.
Old Sep 5, 2024 | 08:34 AM
Gauchobyte's Avatar
Tx to all, definitively I will made my own version of a tool. Best. Raul
65droptop
Mar 22, 2022 11:56 AM
Napoleon1991
Aug 11, 2020 07:21 PM
jrainwater73
Feb 28, 2015 10:02 AM
Stevec
Aug 12, 2012 03:12 PM
martine
Apr 2, 2004 09:25 PM
