Does anyone know where this mount goes!
Old November 4th, 2012, 09:34 AM
Marc A Levy's Avatar
Hello again to everyone!
I'm putting my 70 toro back together and I have this mount that I can't figure out what it supports any suggestions are appreciated?
Thanks Marc
Marc A Levy is offline
Old November 4th, 2012, 09:37 AM
I think it's a engine mount or transmission mount of some sort.
Here's a picture of where I'm at!
Old November 4th, 2012, 09:42 AM
Pacecar's Avatar
Looks like lower power steering or alternator mounting brace. Is car an A/C car ?
Pacecar is offline
Old November 4th, 2012, 09:44 AM
Yes has a/c!
Old November 4th, 2012, 06:13 PM
Thank you! It was lower power steering mount you were right! All mounted up and hopefully I will have it on the road as soon as I can afford to get a new core for my radiator as I can't fid an aftermarket anywhere! Thanks again!
Old November 4th, 2012, 06:19 PM
Pacecar's Avatar
Don't forget to mount the spacers for the power steering pump. One goes behind the lower front bolt. the other mounts to the side of the block and is important for getting the pullys lined up straight. otherwise you will wear out your belts in no time. Washers work if you don't have the original spacers. just check the alignment
Pacecar is offline
Old November 4th, 2012, 06:33 PM
Originally Posted by Marc A Levy
I think it's a engine mount or transmission mount of some sort. Here's a picture of where I'm at!
You sure? Looks like it belongs in the land down under.... Sure you didn't mean to come out upside down. Easier to see like this:
Glad you found out where the part went to. Now, about that rad support.....
Allan R is offline
Old November 4th, 2012, 07:01 PM
That is much better! Now I see it differently and I can pick out a couple of cosmetic things I would like to fix! Thanks for turning me around!
Old November 4th, 2012, 07:04 PM
As for the spacer, I have a feeling that I should have used one but when I looked at the alignment it seemed ok and the only spacer I have after reinstall is almost a half an inch and it seems as though it would be really off then?
costpenn
August 29th, 2018 11:42 AM
junkman454
April 26th, 2011 10:46 AM
import extermination
August 1st, 2009 10:09 PM
IDAS 69
March 1st, 2009 06:05 AM
esisson
November 17th, 2008 05:39 PM
Quick Reply: Does anyone know where this mount goes!
