Does anyone know where this mount goes!
Hello again to everyone!
I'm putting my 70 toro back together and I have this mount that I can't figure out what it supports any suggestions are appreciated?
Thanks Marc
Thanks Marc
Thank you! It was lower power steering mount you were right! All mounted up and hopefully I will have it on the road as soon as I can afford to get a new core for my radiator as I can't fid an aftermarket anywhere! Thanks again!
Don't forget to mount the spacers for the power steering pump. One goes behind the lower front bolt. the other mounts to the side of the block and is important for getting the pullys lined up straight. otherwise you will wear out your belts in no time. Washers work if you don't have the original spacers. just check the alignment
Glad you found out where the part went to. Now, about that rad support.....
As for the spacer, I have a feeling that I should have used one but when I looked at the alignment it seemed ok and the only spacer I have after reinstall is almost a half an inch and it seems as though it would be really off then?
costpenn
Aug 29, 2018 11:42 AM
import extermination
Aug 1, 2009 10:09 PM
