Does anyone know? - Clutch Fan Question
Old Nov 16, 2008 | 09:33 AM
esisson's Avatar
3 dumb questions: (actually, 2 decent and 1 dumb question)
There are 6 blade fans and there are 7 blade fans. Can anyone tell me if the OEM cooling fans for Olds is model specific, engine specific, or other?
Also, is it safe to assume that a 7 blade fan has more cooling capacity than a 6 blade fan? Common sense says "yes" (more air flow), but I'd like to hear a more scientific explaination if possible.
Also, Do you think a 7 blade fan is noisier than a 6 blade?
Thanks in advance.
Old Nov 16, 2008 | 10:11 PM
BILL DEMMER's Avatar
Just the facts...
there were also 5 blade fans and 4 blade fans. 4's were typically used in non-a/c equipped cars, 5's were usually the standard v-8 a/c application fans, 6's were the heavy duty fans, and 7's were for the diesel's or toronado's.
the 7 blade fan doesn't necessarily move more air, the blade pitch has to be taken into account. they could use more blades with a smaller pitch to help keep fan noise down. basically there are several factors involved. blade pitch, size, and shape are what pop into my mind, right off the bat. the early toro's got 7 blade fans due the small grill area on those cars, the diesel's got them because they ran hot. it stands to reason that with all other factors being equal, more blades should move more air and make more noise doing it.
bill
Old Nov 17, 2008 | 07:39 AM
Do all of the fans fit inside the same shroud? If so, why doesn't everyone change to a 7 blade fan unless they don't like the noise or are going for originality?
Old Nov 17, 2008 | 07:43 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Are you curious because you have a cooling issue already?..... Or because you wish to avoid one in the future?
In my experience going from a 5 blade fan to a 6 or 7 blade fan on the snout of the water pump makes little noticible difference.
If you bolt 1 electric fan against the radiator, you will notice the difference right away.
Old Nov 17, 2008 | 09:10 AM
Just the facts...
the more air you move-the more power you steal from the wheels. if you don't need 7 blades, you would be wasting the power it steals. now, it's not really going to change your quarter mile times much, but too much doesn't accomplish anything.
bill
Old Nov 17, 2008 | 09:27 AM
True. I was just curious. My 71 98 is running fine.
Old Nov 17, 2008 | 04:55 PM
esisson's Avatar
Fan
I picked up a 7 blade fan from a Toronado at the local junkyard. It was cheap and I was just pondering whether or not to install it. I'm not currently having any cooling issues, just curious as to what they commonly came on.
Observation:
The 6 blade fan is about 9 inches and the 7 blade from the Toro is about an inch smaller which might eliminate some clearance issues people may have with their fan shrouds.....
Old Nov 17, 2008 | 05:10 PM
Lady72nRob71's Avatar
Originally Posted by esisson
Observation:
The 6 blade fan is about 9 inches and the 7 blade from the Toro is about an inch smaller .....
A 9" fan?
That was the fan size on my sisters old hundai excel...
You must have meant 19"...
Old Nov 17, 2008 | 05:39 PM
esisson's Avatar
LOL! You're right. I fat fingered that one. Thanks.
RandyS
Jul 6, 2021 07:45 PM
costpenn
Aug 29, 2018 11:42 AM
47 Convertible
Apr 3, 2014 07:56 AM
RandyS
Mar 8, 2014 05:07 AM
IDAS 69
Mar 1, 2009 06:05 AM
