axle nut
Old Aug 16, 2013 | 02:54 PM
walter thornberg's Avatar
axle nut
i hope one of you guys can help iam changing the front left driveshaft on my 67 it was throwing grease went to oreillys and exchanged the axle all was well same length same bolt pattern but the axle nut is smaller i understand that it is the same axle on eldorados up till 76 any one know the size ? it is metric seems like a 22.0mm x 1.5mm went back to oreillys and my core is gone
Old Aug 18, 2013 | 12:24 PM
coppertopgmc's Avatar
I would say they gave you the wrong cv axle. the axle nut should not be metric even on the 78 models. My axles came from napa they did not come with new nuts because the old ones are not lock nuts but use cotter pins so they are reuseable
Old Aug 19, 2013 | 05:57 AM
Just got to work (Napa) measured the cv axle on the shelf, looks to be 1 in. 20 thread pitch.
Wasted
Oct 26, 2018 02:57 PM
bob p
Jun 4, 2015 01:53 PM
bobmobile
May 6, 2015 02:29 PM
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
mcutlass1969
Aug 18, 2008 09:59 PM
