67 Toro front door handles
Old Dec 7, 2011 | 07:35 AM
Frogge467's Avatar
67 Toro
I have a 1967 Toro with interior handles for opening the doors from the front or back seats on each door. The handles for back seat passengers work great. The handles designed for front seat passengers are not working. I currently have the drivers side door panel off, just finished the fiberglassing of the broken area for seat/window controls. The mechanism in the door is in tact, there seems to be some play in the pivot point for the handle. Any suggestions?
Old Dec 7, 2011 | 09:00 AM
2blu442's Avatar
There should be splines inside the door handle that fit over the shaft of the mechanism. Is it the handle that's showing wear and not fitting tight? Is the screw that holds the handle to the mechanism tightening properly? Either way I would suggest you replace the worn/damaged parts, either the door handle or release mechanism. If you can identify where the problem is I'd encourage you to create a parts wanted thread. There should be a few members here with spare parts from early Toronado's. John
HonestDave
Jun 27, 2013 07:19 PM
gbrewer
Jan 29, 2010 02:46 AM
442_Mustang
Body work
Aug 17, 2009 07:28 PM
bcg88
Body work
Feb 10, 2009 09:43 PM
Big Joe P
May 23, 2007 01:18 AM
