Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Best fitting headers 1972 455
Old Dec 22, 2020 | 02:41 PM
tyler1972's Avatar
Just curious what headers you guys have had luck with... I currently have older set of hookers that hang quite low and wondering what everyone else has had luck with..
im currently looking at a set of Dougs..
Old Dec 22, 2020 | 02:45 PM
They hang low probably because your car has been lowered from looking at your picture.
Old Dec 22, 2020 | 07:16 PM
tyler1972's Avatar
the car is lowered, however the sit about 2.5" lower than the frame and have about 4" to the floorboard.
Old Dec 30, 2020 | 11:58 AM
dc2x4drvr's Avatar
ARH SS headers fit perfect, don’t hang below the frame.
Old Sep 14, 2021 | 09:31 AM
android 211's Avatar
On my '72 project I bought some good used headers and had them coated. When I installed them one tube rubbed on the brake junction block bolted to the frame under the master cylinder. I have read of this problem before but maybe its my motor mounts? My car is a U code, 455 but when I bought it there was a 350 2bbl under the hood. Now it has a '72 455 but the fan is too low in the shroud and rubs at the bottom inside. I guess I should look into whether I have the right mounts?
Old Sep 14, 2021 | 10:06 AM
69455's Avatar
X2 up tight great fit.
Old Sep 14, 2021 | 01:27 PM
RetroRanger's Avatar
72 Olds CS
probably just whipped motor mounts my fan rubbed at the bottom of the shroud too, one motor was broken in half and the other was just compressed new mounts fixedthe fan rub. Assuming your shroud and radiatior are in good shape and correctly mounted.
OLE442
Jun 13, 2020 08:49 PM
QS442
Oct 16, 2019 02:17 PM
h&jcs
Jun 12, 2019 04:39 PM
Kyle's 77 Cutlass
Apr 13, 2014 11:30 AM
SRV8
Nov 7, 2012 08:13 AM
