Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
69 olds 442 - lower radiator hose diameter/dimensions?
Old Sep 21, 2021 | 11:25 AM
arruv89's Avatar
Need some help finding the correct size diameter for the lower radiator hose (radiator side). I've bought 1 from OPGI, 1 from NAPA, and a universal one. All the inlets for the radiator side are slightly too big at 1-3/4". Can someone please confirm the correct size? I'm guessing 1-5/8" but I can't find find the info in my manuals (reprint/blurry small words)
Thanks for the help!
Old Sep 21, 2021 | 12:02 PM
Give Fusick a call and see if they can help.
Old Sep 21, 2021 | 12:07 PM
v8al's Avatar
Registered Olds Owner
I had similar issues. See if this post helps out:
https://classicoldsmobile.com/forums...p-hose-154145/
Old Sep 21, 2021 | 12:57 PM
Yeah, I suspect the hose is the correct size, but the radiator has been changed to a '71-up version that has a smaller diameter fitting.
Old Sep 21, 2021 | 01:01 PM
Yellowstatue's Avatar
There is a rubber bushing available for this problem.
Old Sep 21, 2021 | 03:39 PM
RetroRanger's Avatar
72 Olds CS
I used a gates rubber bushing to accommodate my 70 waterpump VS 72 radiator mismatch they work very good w no issues
I dont recall the exact one tho
Old Sep 21, 2021 | 04:02 PM
I just read this again. The 71-up radiator has a 1 1/2" outlet compared to 1 3/4" for the 70-older versions, so you will need one of the rubber sleeve adapters as stated above to convert from 1 3/4" to 1 1/2".
Gates 26391
https://www.rockauto.com/en/parts/ga...d.+reducer,385
https://www.oreillyauto.com/detail/c...t0/26391?pos=1
Dave S
Jun 11, 2021 07:56 PM
harpelt
Apr 3, 2016 04:01 AM
Christophe2m6
Jun 21, 2015 03:23 PM
1979 hurst olds
Jun 17, 2013 03:50 PM
Iragh
Nov 17, 2008 01:23 PM
