Fuel filter on suction side of fuel pump??
Joe, I have a question for you, or for any one else with input. This is not a Olds question but could pertain to one. I have a 1956 F100 with a 80's Ford 300 6cyl. When i put it together I used a repop original style gas tank. I have had multiple carb problems (clogged jets- sticking float, etc). I am pretty sure this is happening because there is weld slag, dirt, etc, inside this tank. The carb is a Carter YF, with a threaded filter at inlet of carb which has been replaced 2 or 3 times, but it has allowed this junk to get in carb. As far as I have seen the auto manufacturers never put a filter on the "suction" side of a mechanical fuel pump, always on the discharge side. Do you think I could put a filter before my fuel pump to hopefully stop this issue? It seems to be great until I take this truck on a trip, did it last year in Pennsylvania and again this year in Kentucky. What cha think?? Thanks Greg.
Greg - Personally, I've never placed an in-line fuel filter on the discharge side of a mechanical fuel pump. I installed an in-line fuel filter before the mechanical fuel pump on my 71 CS 350 convertible w/ absolutely no issues. If I were going to mount an in-line fuel filter it would be prior to the mechanical fuel pump. I'd prefer the slag & gunk were filtered prior to hitting the mechanical fuel pump's diaphragm.
I've done it both ways and either way works. The only reason I prefer the discharge side is because I don't like fuel running into my armpits changing it on the inlet side.
I've used inline filters on the suction side on several vehicles to prevent trash from messing up the pump. It can't hurt. Be sure to use a high flow filter. For stock-ish applications I like the Wix 33033 also.
There's no shame in siphoning the tank before hand, then disconnecting the fuel line at the pump and letting it drain while you have a beer before beginning work. I even swabbed my dad's corvette's tank when I did the fuel pump last winter because you can do that on those cars.
I've found that the lazy way to empty a tank is to disconnect the fuel line at the pump, run it into a catch can, and use shop air at the tank inlet to pressurize the fuel out of the tank. Use a rag and a blow nozzle in the filler neck. Be careful not to overpressurize the tank when you do this (ask me how I know this... ). This gets most of the fuel out, to the point that the tank is light enough to drop easily.
I just back the car up on my ramps and siphon as much as will come out. The tank isn't heavy at all with whatever amount is left in there. My Toronado's tank is pretty low to the ground like this and I can still get most of the fuel out.
Has anyone seen the Dave Frieburger/Roadkill fuel filter setup?
Anytime Dave or the guy from Junkyard Rescue revives a long dormant car or truck, they will string a bunch of those cheap inline filters together. That way when the first filter clogs with crap from the tank and lines, you simply remove the clogged filter and connect the line to the next filter and keep going. When it clogs, remove it and reconnect the line to the next filter, and start driving again.
Eventually, the filters catch all the trash, or hopefully you made it home so you can do a proper repair.
There is no strainer- never was made for one. This thing is completely different than what we were used to in most cars. There is a hole about 2" in diameter that the float goes in thru. The fuel line is separate. It is actually welded to the bottom of the tank and had to be installed before the 2 halves of tank was assembled. You can see it thru the hole if you use a small bic lighter and look thru the hole... NO NO , maybe better to use a small flashlight..... Yuk Yuk...
Call me crazy but the last 5 tanks I’ve had new or happened to have out of the car, went to my friendly radiator guy to braze in a 1/4” NPT bung in the low spot on the bottom. I put either an Allen head plug or regular old drain **** in. Obviously tanks being reused get thoroughly cleaned out.
I’m missing a leg & half a pelvis and this sure makes draining, tank removal or gauge verification a simple, easy procedure, especially since I’m working alone, though I was doing the drains prior to my “situation” befell me..
Thanks for the kind words, just hit 6 year mark pretty much on the nose. I get by surprisingly (at least to others) well, but everything takes a lot more time, effort, ingenuity and determination. Happily I have a 4 post lift and doing underside work while sitting in my smaller “gimp scooter” makes for almost leisurely toil!
I even replaced the flex plate & converter seal, along with a rear axle swap in my el Camino recently, didn’t even manage to hurt myself!
When I changed to EFI, I added a 100 micron filter just after the tank. Whether it did anything, who knows. I still have it in place with the Qjet with the Napa Gold 3/8" metal filter before the carb.
--Well guys, I took truck down state last Saturday and didn't make it back. Ran great on way down, then shut off at my buddies place for about a hour. When restarted it sort of missed, then when accelerating bucked and snorted. I stopped and looked everything over and seemed better. I thought -of course- that the fuel tank, crud, etc, was the problem. Well I decided to hit the highway and it ran fine for about 15 miles. Then right after a exit, it quit. Next exit was maybe 7-10 miles. But it started running again! I decided to forge ahead and stop at next little town and leave truck there. Made it about another mile and it quit for good.... Had to get a wrecker. Had it towed back to a big truck stop.
-- Next day went down with a towbar. Truck started right up, but still decided to tow it. Good choice.. it never would have made it. Next day I am trying to figure out what I am gonna do about this "fuel " issue....Started up truck and it ran for about 3 minutes, then abruptly quit- like it was shut off- not like a fuel issue.. So I hooked up my timing light and when truck abruptly quits- so does timing light flashes!! Ignition is dying!! Bought a new coil and it's running great again-
-- Well I still may have a problem w/ fuel/crud/etc, or maybe it was all cuz of weak/dying ignition..
Love1955oldsmobile
Jun 15, 2022 08:16 AM
RAMBOW
Jul 30, 2013 03:40 PM
