Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
air filter
Old Oct 19, 2020 | 06:43 PM
WARS442's Avatar
air filter
Does anyone know the correct air filter part number for a 66 442 original air cleaner?
Old Oct 19, 2020 | 07:46 PM
Hairy Olds's Avatar
Shoveling Snow
Should be A90CW. Manual or auto?
Old Oct 19, 2020 | 08:42 PM
Ozzie's Avatar
The 1966 Oldsmobile Parts Catalog shows two possibilities for the 442 under group 3.410 (air cleaner element):
If the quadrajet, part number 6421746
If the Tri-carb, part number 6420700
Old Oct 19, 2020 | 09:10 PM
Did manual (open element) applications use the same filter element as automatic (closed element) applications in '66-7?
Old Oct 20, 2020 | 05:56 PM
Ozzie's Avatar
Only one was in the parts catalog for the 4BBL. It didn't distinguish between manual or automatic transmissions.
Old Oct 21, 2020 | 03:35 PM
CRUZN 66's Avatar
Olds Fever
The Tri-Carb number you show 6420700 doesn't show up in any of my parts info starting in 1972... 6422468 (A220C) is the most current that I show for the Tri-Carb setup...
Old Oct 21, 2020 | 05:21 PM
Ozzie's Avatar
Perhaps the part number changed after 1966.(?)
Human
Dec 10, 2022 07:04 AM
76olds
Aug 26, 2016 08:56 AM
sammy
Feb 11, 2015 12:44 PM
DeltaDevil88
Jan 1, 2013 09:13 PM
BStone
Aug 8, 2011 10:16 AM
