1966 Tri Carb Questions
I'm restoring a '66 L69 setup. I have the three correct carbs, including the 575 center carb. My Plan is to sell the completed setup after restoration.
Are gaskets available for the two exhaust crossover covers, or do I need to make my own?
Also, What should I apply to the bottom of the manifold to keep it from rusting until it is installed on an engine?
Is the Duplicolor DE1604 Gold close to correct for the engine color?
Does anyone know of a source for the AC glass bowl fuel filter? The OEM one has 1/4 NPT female threads. Any I've seen are only 1/8 NPT.
Thanks for the answer on the block-off plates. Any clues on the correct color and/or the glass fuel bowl?
I had to make a gasket for the thermostat housing. The Fel-Pro gasket paper is really nice--about 3/32 thick, but really tough, not easy to tear, but easy to cut to fit.
Finding the correct glass bowl filter won’t be easy or cheap.. Mike on this site may have one, he has a lot of original tri carb stuff. 66-3x2 442 is what he goes by on this site..he answered one of your questions..private message him.
jcdynamic88
July 27th, 2020 07:41 PM
Tedd Thompson
March 19th, 2020 04:18 PM
RAMBOW
January 29th, 2016 11:53 AM
