Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
1969 Quadrajet 7029251 question
Old Oct 25, 2024 | 05:45 PM
Kevin's442's Avatar
I'm rebuilding the quadrajet for my 1969 442. It's a 7029251. The engine is pure stock so I plan to keep the jets, rods etc. all original. Now the problem. A previous owner removed the main air bleed inserts from the air horn leaving me with about a .125 upper main air bleed. I'm not sure what size opening it's supposed to have, but I know that wide open is not correct. Does anyone know what size a 7029251 should have?Thanks in advance.
Old Oct 25, 2024 | 09:02 PM
bccan's Avatar
I’ll apologize in advance, I don’t have info on that particular carb but I’ll check some notes on carbs I’ve worked on so that you’ll have an idea of range. If nobody nails it for you with accurate & relevant info, I’ll see if I have some more info on such things tomorrow when I get out to the garage.
……….………………..…….Stock……………..…Mod ……………...…Stock …….……..Mod . . . . . . . . .. Stock
………………….…………….SBO ……….…….434 SBO………..…….BBO…….…..……SBO . . . . . . . . . . BBO
……………………………..7041250…….…..7040258……….…..7043252……….7042250 . . . . . . .7040251
45* on Venturi leg -. .049 . . . .. .. .070 . . . . . . . . .. .042 . . . . .. .042 . . . . . . . . . . .. .040
Next to tapered ….... .040 . . . .. .. .053(stk.047) .. .. .040 . . . . .. .055(stk040) . . . . .. .040
Head screws
So, it looks like .040” is the size.
Old Oct 27, 2024 | 11:01 AM
Kevin's442's Avatar
Thanks for checking, bccan. In my collection of carburetors, I have a 7028251 Q-jet from a 1968 442 and it has .040" upper air bleed inserts as well. It looks like that was the "go to" size for a bunch of Oldsmobile quadrajets in those days. I'd love to be able to ask Oldsmobile's engineers why they went with the jet/ rod/ bleed combos they chose, but it all worked, so I'll go with it.
Thanks, again
Old Oct 27, 2024 | 09:47 PM
shiftbyear's Avatar
Contact Cliff Ruggles. There are bushings available you can press in & redrill to size.
Fisher442
May 9, 2022 05:36 PM
Neil Morrison
Apr 26, 2020 10:16 AM
Diego
Nov 27, 2015 10:24 PM
69ishHoliday
Oct 4, 2013 04:25 AM
