1969 gearing question
Old Nov 24, 2015 | 01:45 PM
Diego's Avatar
What 5-series gears were available in 1969? Perhaps high-4-series too?
Thanks!
Old Nov 25, 2015 | 06:21 AM
From the 1969 SPECS booklet:
Old Nov 25, 2015 | 06:55 AM
junior supercar's Avatar
4.33 and 4.66 which are listed above. there is also dealer installed 5.00 and I know Brian Trick and others (Dave B?) have said there was a small run of I think 5.13. I'm talking Type O gears
Old Nov 25, 2015 | 10:55 AM
Diego's Avatar
Thanks . . . someone told me their car had 5.00 but wasn't sure if it was 5-even or something like that (kinda like how some brands have 3.90 and others have 3.91).
Old Nov 25, 2015 | 12:57 PM
toymobile's Avatar
They did that odd # thing to stop wear pattern repeat.
Johnny
Old Nov 25, 2015 | 01:05 PM
Bob Kelso's Avatar
I have a nos 5:00 ring and pinion for the o-axle . It must be used with the 588 carrier or the 672 carrier . Asking $300 plus shipping from zip 60034
Old Nov 25, 2015 | 10:10 PM
I don't think that the 5.00 gear was available until 1970.
Old Nov 26, 2015 | 06:55 AM
I believe you are correct. The 1968 SPECS book also only shows 4.33 and 4.66. Of course, a 5.00 gear set from 1970 could have been installed in a 1969 Type O housing once they were available.
Here's the 1968 page:
And here are pages from the 1970 powerteams booklet that show 4.33, 4.66, and 5.00 being available (see the fine print at the bottom of the chart):
Old Nov 26, 2015 | 07:42 AM
If a G70 tire was 27 inches in diameter, I get 5000 rpm at 80 mph in top gear with 5.00s. That's screaming.
Old Nov 26, 2015 | 08:26 AM
Correct. Of course, these are drag race gears. 10" slicks are typically 29" or 30" diameter. Even at that, however, if you are running 100 MPH in the traps, your hitting about 5600 RPM (admittedly very briefly). Also consider that slicks will grow slightly as tire RPM increases. The more important issue is how the 5.00 gears help your 60-ft times.
This is also a great example of how you need to match the gears to the tires to the car weight to the engine power band to the transmission etc etc. The need to shift THREE times in the quarter (with a four speed) probably negates any advantage of the 5.00 gears.
Old Nov 27, 2015 | 04:47 PM
69442murph's Avatar
this one has 4:66 installed in late 69 by Berejik ...the original 3:91's are still with the car and will be re-installed at some point....but it is fun to drive!
Old Nov 27, 2015 | 10:20 PM
That Saffron W31 is sweet.
Old Nov 27, 2015 | 10:22 PM
z11375ss's Avatar
Senior Moment Member
That thing has to JUMP!
Old Nov 27, 2015 | 10:24 PM
Diego's Avatar
Yeah it is!
Bluemeanie
Drivetrain/Differentials
Sep 23, 2012 05:37 PM
crjeeper
Nov 16, 2010 06:15 PM
1970_442
Jul 6, 2010 11:07 AM
procharged70cutlass
Dec 21, 2009 03:24 AM
jonstringer
May 24, 2008 12:45 AM
