Steering Clearance Issue
Old Jun 9, 2025 | 04:25 PM
Taz54904's Avatar
I have an "overseas" front suspension (it was on the car when I bought in Jan 2024). As you can see the part of the steering in Yellow is contacting the lower control arm in Red. Is there any fix to this besides junking the "overseas" suspension? Can part of the "tab" in Yellow be cut down to clear the suspension? The only time that I have an issue with it is when I am trying to do a tight turn. Thanks!
Old Jun 9, 2025 | 04:52 PM
Taz54904's Avatar
I posted this elsewhere and found out that this is a fixed travel stop. You learn something new everyday!
Old Jun 9, 2025 | 07:58 PM
If it is contacting on only one side, then your steering box may not have been centered prior to the alignment.
Old Jun 10, 2025 | 08:25 AM
Taz54904's Avatar
It's on both sides.
I didn't notice it last year because the tires where hitting the HD sway bar. Then this year I did a front disc brake conversion (which pushed the rims/tires a little wider) and now the tires don't touch the sway bar but now the steering stops work again. LOL
Old Jun 10, 2025 | 10:33 AM
Rallye469's Avatar
Yep. Mine did the same.
It had a date with my grinder.
george landis
Suspension & Handling
Nov 30, 2022 01:46 PM
BSiegPaint
Jul 13, 2021 03:50 PM
Coraxolds
Sep 19, 2020 03:04 PM
67townsedan
Sep 16, 2013 03:25 PM
White_Knuckles
Jun 17, 2013 02:41 PM
