Front Suspension swap on 64 Jetstar 88?
Old October 25th, 2009, 08:06 PM
bourbon's Avatar
Well, i was working on the front suspension on my Jetstar today, and I see that it is not going to be low enough for me with just air bags. And since I want to convert to disc brakes up front, I think the best thing to do is get a drop spindle and then do the disc swap at the same time as the bags. I think I should be able to get a-body ball joints for a chevelle, and swap them into my arms, then get the chevelle drop spindles and disc setup. am I thinking right, or will those ball joints not work in my arms? Am I right about the Jetstar being an a-body?
bourbon is offline
Old January 16th, 2010, 07:47 AM
Will NEVER Grow Up!
Ddbord's Avatar
Not an A-Body!
I don't know if you can use Chevelle parts on your front end, but the Jetstar 88 is a B-Body car with the same specs as any other 88. The brakes are smaller.....
Best wishes,
Ddbord
Ddbord is offline
Old January 16th, 2010, 06:07 PM
Nope. Despite the marketing that it uses A-body suspension, it does not. It uses special spindles that are unique to the 1964 J-88 to mount the 9.5" A-body front drums on the B-body suspension arms. The Chevelle spindles WILL NOT work. For starters, the J-88 is rear steer (steering linkage behind the axle centerling) and the A-body is front steer. Aftermarket disc brakes are your only choice, and I'm not aware of any lowering spindles that fit.
Since the question will undoubtedly come up, Impala spindles won't work either. The 1964 Impala chassis and suspension is completely different from the Olds B-body cars and nothing interchanges. As an example, the lower ball joint on the Impala has the stud pointed down, the Olds has the stud pointed up.
joe_padavano is offline
enginenine
January 1st, 2014 10:56 AM
EmilyAndTheJet
August 20th, 2011 08:29 AM
DonL
April 2nd, 2009 07:29 AM
delta881972
Drivetrain/Differentials
January 2nd, 2009 06:54 AM
Jetstarjockey
May 18th, 2006 01:40 PM
Quick Reply: Front Suspension swap on 64 Jetstar 88?
