Tubular Control Arms
Old Aug 4, 2024 | 02:49 PM
jdclemons's Avatar
I'm in the process of installing tubular control arms on my 71 cutlass. You're suppose to torque the bolts on the control arms with the car down on it's tires. My question is will there be a difference since I haven't installed a motor in my car yet or should I wait till the motor is in then torque the bolts. Thanks
Old Aug 4, 2024 | 03:03 PM
Wait. The suspension needs to be loaded at normal ride height.
Old Aug 4, 2024 | 03:18 PM
jdclemons's Avatar
So you're saying put everything together and wait till motor is in and then torque everything down. I'm going with coil overs so I will need to set ride height on those then torque everything down.
Old Aug 4, 2024 | 04:37 PM
gs72's Avatar
72Cutlass S
Yes torque all rotating suspension points at loaded ride height.
Old Aug 5, 2024 | 07:24 AM
oddball's Avatar
What type of bushings?
Rubber: Yes, definitely. Just wait.
Polyurethane/Delrin/other plastic: Go ahead and torque now.
The mounting ears squeeze down on the inner sleeve and stop it from rotating. The outer sleeve is always narrower, and the bushings themselves always have some give. In rubber bushings, the inner sleeve is bonded to the rubber which is bonded to the outer sleeve, so they rubber stops the sleeves from rotating. That's why if you torque them when drooped, then the rubber is constantly twisted and will tear much sooner.
On poly/plastic bushings the inner sleeve can rotate separately from the bushing, and the bushing can rotate separately from the outer sleeve, so this isn't a problem.
Old Aug 5, 2024 | 12:54 PM
Good point on rubber vs poly. I just figured with his statement "You're suppose to torque the bolts on the control arms with the car down on it's tires" that the instructions on his parts said to do that.
Old Aug 6, 2024 | 06:03 AM
oddball's Avatar
The manufacturers include the same instructions with poly/delrin parts also. "Just Because". It's easier to say the same thing than to spell out the details - like the 14" wheel and disc brake thing.
James J
Suspension & Handling
Dec 10, 2023 07:45 PM
Rob64cutlass
22
Nov 19, 2023 07:07 PM
330jetstar
Drivetrain/Differentials
Mar 17, 2023 10:44 AM
cbartonbrown
Oct 7, 2019 08:26 AM
big_wheel1971
Jul 22, 2010 06:28 AM
