Steering box upgrade question?
Old Sep 4, 2016 | 07:30 PM
1968_Post's Avatar
Okay, I'm in the middle of a Jeep Cherokee gearbox swap. I'm to the point of installing the fittings to adapt the box to flare fitting style hoses. I'm using the Borgeson 925122 fittings. Problem is, there are 3 bushings in the kit. none which will press into the pressure side of the box. They're all too small and just lay in the pump with no friction fit.
So here's my question... does it matter that the fitting wont press in? Once the hose is attached, that fitting isn't going anywhere.
Am I misguided on this?
Old Sep 4, 2016 | 07:41 PM
allyolds68's Avatar
Jeff,
I had basically the same issue as you but one of mine pressed in tight and the other just laid in there. Both sealed tight and worked fine. I got the fittings from Summit
Old Sep 4, 2016 | 07:52 PM
1968_Post's Avatar
Thanks Mike, this was driving me nuts!
I was sure I did something wrong, even though I checked at least 5 times before tapping one in. I got the return side pressed in but the pressure side was a no go. I'll finish that bugger up tomorrow...
Then I can look for something else to be paranoid about!
enginenine
Suspension & Handling
Oct 14, 2015 08:32 AM
jaymann
Nov 30, 2012 03:15 PM
RetroRanger
Sep 15, 2011 08:09 AM
Aceshigh
Jun 8, 2011 06:12 AM
agtw31
15
Jun 14, 2010 06:01 AM
