Rear Shocks
Old Sep 9, 2016 | 05:53 AM
oldsguybry's Avatar
NOVICE car nut
Rear Shocks
I'm going to have to get some new shocks because the car currently has some real old air shocks and they don't hold air in them very well anymore , and they look quite old . Do you think these would be a decent replacement ?
I kind of want the rear up a bit , that's why I was looking at these .
Old Sep 9, 2016 | 06:03 AM
If the car does not sit at the level you want without the airshocks aired up then I suggest a new pair of springs. The upper shock perches are not meant to support the cars weight. The coil assists are a good combo with new springs, however the ride will be very stiff.
Old Sep 9, 2016 | 06:09 AM
Agreed. New springs are not expensive.
CargoCoils are probably the best, because they are a bit firmer, and maintain the ride height better with a load.
If you want it high, get station wagon springs.
If you want to go cheap, get them at the junkyard.
Old Sep 9, 2016 | 10:20 AM
oldsguybry's Avatar
NOVICE car nut
Good info , thanks
Old Sep 9, 2016 | 12:28 PM
76olds's Avatar
Hookers under Hood
X3, I would stay away from the pic you posted " Load leveler shocks" so they are called here.
Wagon coils and shocks if you want height as Eric suggested would be the way to go.
Eric H
Old Sep 9, 2016 | 12:36 PM
droptopron's Avatar
delete
Just for ref, Rock Auto has rear springs starting around $50 plus insulators for $3
Old Sep 10, 2016 | 07:19 AM
oldsguybry's Avatar
NOVICE car nut
Thanks for your input guys .
71RadioflyerVista
Suspension & Handling
Mar 14, 2011 11:00 PM
Noisemaker
Mar 13, 2011 01:50 PM
AZ442
Aug 24, 2009 07:32 AM
aristellier
Dec 19, 2006 03:51 PM
