stiff steering after steering box replacement
Old May 21, 2010 | 04:18 PM
agtw31's Avatar
put a quick ratio box in the delta,now it feels like my power steering isnt working,steering is very stiff.
do i have something too tight?
is the box i put in junk?
Old May 21, 2010 | 06:04 PM
Blk71SX's Avatar
did you completely bleed the system?
if so, the gear could be bad
Old May 21, 2010 | 06:13 PM
OLD SKL 69's Avatar
GM Enthusiast
If you have not done this yet, try turning the steering wheel all the way side to side a few times. (Easier to do if you have the front wheels off the ground) That should get rid of all the air in the system. If you still have the issue, then you could try backing off the adjustment screw on the top of the box to see if that helps.
Old May 21, 2010 | 06:42 PM
agtw31's Avatar
it's still doing the same thing even after adjusting the box both ways.
there is even play in the steering
frigging junk
Old May 21, 2010 | 07:07 PM
OLD SKL 69's Avatar
GM Enthusiast
Yep, it sounds like they gave you a junk box. Hope they honor the deal with a free replacement.
Old May 22, 2010 | 10:36 AM
agtw31's Avatar
guy is sending my money back,went to auto zone and bought a new one
what i should have done in the first place
Old Jun 3, 2010 | 01:48 PM
Mikes65's Avatar
What brand is the junker---? we need to know so we can avoid that seller/brand.
Old Jun 4, 2010 | 05:44 AM
Yes, please let us know.
Old Jun 4, 2010 | 06:15 AM
MN71W30's Avatar
I used a 90's Jeep box in my 65 Chev and it works better than any I've had before.
Old Jun 4, 2010 | 08:46 AM
I wonder if that swap would work on an Olds?
Old Jun 4, 2010 | 09:51 AM
MN71W30's Avatar
It'll bolt right up. I had to buy an aftermarket rag joint and a high pressure hose from a 80 Camaro and flare one fitting. It's under 3 turns lock to lock.
Old Jun 4, 2010 | 10:50 AM
Interesting!
Old Jun 12, 2010 | 02:20 PM
jwesterling's Avatar
steering box
I have a 64 cutlass.I dont know what kind of box it has but steers great only about 2 !/2 turns lock to lock.My problem is it turns sharper to the right than to the left.Any Help?
Old Jun 12, 2010 | 04:53 PM
MN71W30's Avatar
You need to center the steering box then adjust the tie rods so the tires are straight.
Turn the steering wheel back and forth and find the center. Look and see where the tires are pointing, they should be straight. If they are turning to the right you need to adjust your tie rods to make them straight.
Old Jun 12, 2010 | 07:52 PM
cutlass steering
Thanks,I went out and tried to get box centered.You are right,the wheels are turned to the right a little.It seems to be off a little less than a 1/4 turn.I am just getting it on the road.Would you believe i paid 70.00 for front end aliment.The guy was only in business a few months.HUM i wonder why.Thanks again,I will let you know the out come. Jon
Old Jun 14, 2010 | 06:01 AM
I've thought about getting the following tool so I can do my own alignments:
http://www.summitracing.com/parts/SPS-91000/
Arrowstorm
Suspension & Handling
25
Jul 29, 2015 05:52 AM
4424me
May 13, 2012 06:02 PM
Frank3
Jan 12, 2012 06:08 AM
MN71W30
Jul 23, 2009 02:49 PM
