Pitman Arm Question
Old Sep 18, 2021 | 11:04 AM
Phoenix8990's Avatar
Pitman Arm Question
I changed my steering gear on my 69 Cutlass and have a question about how much spline should be exposed after the nut is tightened. I think it was similar before but don't recall. It is tapered and I have tightened it as far as I can get it using a 12" adjustable wrench. I don't have a socket that big or I would use a breaker bar on it. I will probably wind up buying one. Can someone confirm if this is correct?
thanks, Steve
Old Sep 18, 2021 | 11:32 AM
Your adjustable wrench has nowhere near the ability to apply the correct 180-210 ft-lbs on that nut. Buy, borrow, or rent the correct socket and torque wrench.
Old Sep 19, 2021 | 05:11 AM
I agree, I just thought it would snug up a lot more, then torque it. I guess it takes the torquing to get it tight, almost like a press.
thanks for clearing it up, I think. I'll pick up a socket today and see if I am capable of 200lbs.
Steve
Old Sep 19, 2021 | 12:11 PM
So this is torqued to 190#. Is that typical to still have the splines exposed?
Steve
Old Sep 19, 2021 | 12:28 PM
Steve
Yeah, that's normal. So long as you have several threads past the nut like that, you're good to go.
Old Sep 19, 2021 | 01:15 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Just curious, did you use the crescent wrench to get the original nut off?
Old Sep 19, 2021 | 04:26 PM
Yes, I did just use a adjustable wrench.
Old Sep 19, 2021 | 05:16 PM
OLDSter Ralph's Avatar
You may need a 4-5 foot long "tubular torque enhancer" to get that 200 Ft/lbs.
Old Sep 20, 2021 | 08:02 AM
I was surprised, I used a 3/4" drive torque wrench and got it no problem. I was about 28" long. I also thought I would need to extend it.
Steve
67abody
Jun 6, 2019 07:07 AM
cdrod
May 3, 2015 08:37 PM
brown7373
Apr 19, 2015 06:29 PM
dbuck
Mar 29, 2014 11:01 AM
Napoleon1991
Sep 17, 2013 09:25 AM
