New rear coil springs
Old June 27th, 2017, 09:21 AM
Army_Vet's Avatar
I just put new rear coil springs on my '67 C/S. I went with A/Z RCS5385S (made in USA,) which are heavy duty springs. It raised the rear end 1 5/16". Pictures show both before and after.
Army_Vet is offline
Old June 27th, 2017, 09:29 AM
Is that what you were after?
oldcutlass is offline
Old June 27th, 2017, 09:56 AM
Oldsmaniac's Avatar
The after photo looks like it should (Factory Stance) These cars had that look to them....
Oldsmaniac is offline
Old June 27th, 2017, 10:28 AM
Army_Vet's Avatar
I wanted it a little higher, and I figured 50 year old springs were worn out. I may go a little higher after replacing the front coils. It will eventually have a '71 "Hearse/Olds" 455 with a TH400.
It rides much smoother now with the new springs along with the rear sway bar.
Army_Vet is offline
Old June 27th, 2017, 12:20 PM
72 Olds CS
RetroRanger's Avatar
they sell a spacer that fits under the rear spring, i got one in a 1" size to lift the rear a bit but not change the spring rate
RetroRanger is offline
Old July 8th, 2017, 12:59 AM
android 211's Avatar
I put Moog Cargo Coils in back of my '87 Cutlass and also a friends '67 LeMans convertible and in both cases I was happy with ride height, firmness and ride quality. In neither case did the car have a jacked up look at all.
android 211 is offline
Old July 8th, 2017, 06:04 AM
What is a 71 Hearse/Olds? Are you referring to an engine from a Cottington Hearse?
Allan R is offline
Old August 2nd, 2017, 01:18 PM
Jcavall's Avatar
Who sells the spacer? Just put new shocks and springs on and I am not happy with stance. I would prefer it to be slightly higher
Jcavall is offline
Old August 2nd, 2017, 01:45 PM
72 Olds CS
http://www.ebay.com/itm/1-Rear-Coil-...dZC3yW&vxp=mtr
i painted mine black its really hard to tell its on there even when looking at it. theres different sizes I used a 1" but there are 2 and 3" ones too.
RetroRanger
February 25th, 2014 05:04 PM
Bobac455
July 12th, 2013 06:04 AM
Daniel2008
April 17th, 2011 10:40 PM
Lady72nRob71
August 7th, 2009 11:52 AM
cola
June 18th, 2008 08:34 PM
Quick Reply: New rear coil springs
