New larger coil springs in rear of ‘72 98
Old Apr 6, 2023 | 05:07 AM
jpilk99's Avatar
I’d like to put new coil springs in the rear of my 98. I’m a muscle car guy and love the look of cars with a little rake or rear end higher in the air. Only talking 2” or 3”. Also planning to put larger BF GOODRICH COMP TAs all around.
Anyhow, wondering how to find springs that will do the job. I can certainly just buy springs that are literally taller/longer, but there’s also the strength factor. Not sure how to go about this and hoping someone can help. Thank you.
Old Apr 6, 2023 | 05:20 AM
My 71 98 took J78 tires from the factory. That's a 235/75 R15. When I was looking for tires for my 71 98 practically all of the ones I found were knobby SUV or Crossover tires. Don't forget that you have to clear the rear fender skirt on your 72 98.
If your heart is set on going for the raked look I'd suggest air suspension all around. I hope you're a good fabricator. I also hope your tire shop knows how to measure for oversized wheels/tires.
Old Apr 6, 2023 | 05:24 AM
mattking's Avatar
I use this site to compare coil springs by size. it shows size, loaded and unloaded length capacity and a bunch of other attributes. Once I found something I liked I then searched it on rock auto to figure out the OEM application. For example I'm using a 94 caprice chassis under my 55 truck and the stock springs were barely too tall and way way too stiff. I think i went with 84-85 camaro springs that I found on Moog's website below.
https://www.moog-suspension-parts.co...rsal-parts.asp
Old Apr 6, 2023 | 05:29 AM
jpilk99's Avatar
Thank you. Yea, there’s 235/75/15s on there now. I’m not going to do air suspension or anything that involved. I did the same exact thing to my ‘65 Riviera GS and put 275/60/15s on it. LOVED it. But someone else had done the same to theirs and I just bought the same springs.
I’ll keep investigating. Thank you.
Old Apr 6, 2023 | 05:30 AM
jpilk99's Avatar
Awesome possum!! Thank you
dukeomer
Ninety-Eight
Jan 24, 2021 05:42 AM
Army_Vet
Suspension & Handling
Aug 2, 2017 01:45 PM
rmoths
Oct 28, 2013 10:29 AM
dhartley72
Aug 7, 2010 08:28 AM
jpaulwhite
Ninety-Eight
Aug 3, 2010 08:35 PM
