Negative Camber?
Old May 21, 2025 | 10:01 AM
VI Cutty's Avatar
Negative Camber?
Took my freshly rebuilt '70 Cutlass in for an alignment and the shop says there's about a 1.1 degree negative camber with no shims used. What would cause this, and how can I fix it?
The frame is original to the car. I removed shims from both sides when I disassembled everything but I have no idea if the alignment was right or not. The control arms (upper and lower) are from a different car, a '71 Cutlass Convertible - could this cause my problem? New bushings throughout, new balljoints, everything is new.
The front end sits higher than it should and definitely higher than I like, using UMI "Stock Height Small Block" springs which I hopefully indexed correctly. Could the negative camber and higher stance be related?
Old May 21, 2025 | 01:01 PM
madmax442.com's Avatar
madmax442.com
Certainly ride (spring) height will affect your camber. I would make sure your springs are seated correctly. Also, you could get a set of offset control arm shafts. Did the alignment place offer any solutions?
Old May 21, 2025 | 01:22 PM
VI Cutty's Avatar
No solutions from them, but they admitted they don't have the experience with the older cars. I think the old tech they had isn't there anymore unfortunately but I've been told about someone good with these cars nearby who I'll go talk to before committing to anything else.
I have to research the offset and adjustable control arms to see what solutions they may bring to the table...the actual repair will be a winter project but I need to get my head around it and start planning now!
I "think" I had the springs seated properly but it's definitely something I'm wondering about now and need to have a close look at.
Old May 21, 2025 | 02:27 PM
The 64-72 A-body cars have a terrible camber change curve with suspension travel. This is why people use tall spindles or ball joints. In the photo your car looks to be VERY high in the front. This will cause negative camber. The car needs to be at the factory spec ride height for alignment.
Old May 21, 2025 | 02:56 PM
VI Cutty's Avatar
The photo doesn't lie...the front is definitely at least a couple inches too high, certainly higher than it sat before and not how I want it to sit. It sounds like my first goal should be to get it sitting closer to where it should be before messing with control arms.
This would, I assume, mean a closer look at the springs to make sure they're indexed and seated correctly as my first step. The car seems to be sitting square so if one is wrong, I'd think they're both wrong lol. These are new UMI "Performance Stock Height Springs 4049F" for small block applications. With my aluminum heads and intake, I believe the 455 now weighs a touch less than a small block.
Old May 21, 2025 | 03:09 PM
It's VERY easy to get the tops of the springs incorrectly seated in the frame pockets, which causes at least an inch of extra height. Beyond that you may need to cut a coil.
sschevellecutlass_Bob
Suspension & Handling
Feb 23, 2021 10:35 AM
teamwieland
Aug 12, 2019 06:07 PM
1970Ragtop
Feb 6, 2017 06:13 PM
Al Sanchez
Oct 23, 2012 08:20 PM
Mark71
Jan 25, 2012 04:32 AM
