which end goes up
which end goes up
I've got a set of variable rate rear springs for my 68 cutlass s.
buy don't know if the tight spiral goes up or down. Maybe it doesn't make a difference. Any help would be appreciated.
Neither the spring nor the car care which end is up. The response of the springs will be the same either way. Since the end coils are the same at either end, fitment into the spring pockets is not affected.
On variable rate springs (overload not stock, designed for trailer towing) that I have used, they have tighter spaced windings at one end and more spacing at the other. I put them in upside down intially, and the car had more bounce in it, especially when I put the trailer on the back. (1971 Cutlass)
rustycragars
December 25th, 2016 06:06 PM
Maccabeus
December 29th, 2007 09:13 AM
thomaswatk
March 22nd, 2007 01:31 PM
denis
December 22nd, 2006 05:03 AM
