which end goes up
Old Jan 10, 2011 | 08:24 PM
72hurst's Avatar
which end goes up
I've got a set of variable rate rear springs for my 68 cutlass s.
buy don't know if the tight spiral goes up or down. Maybe it doesn't make a difference. Any help would be appreciated.
Old Jan 10, 2011 | 09:51 PM
tomsw31's Avatar
The tighter coils go down.
Old Jan 11, 2011 | 09:08 AM
Neither the spring nor the car care which end is up. The response of the springs will be the same either way. Since the end coils are the same at either end, fitment into the spring pockets is not affected.
Old Jan 11, 2011 | 01:03 PM
tomsw31's Avatar
On variable rate springs (overload not stock, designed for trailer towing) that I have used, they have tighter spaced windings at one end and more spacing at the other. I put them in upside down intially, and the car had more bounce in it, especially when I put the trailer on the back. (1971 Cutlass)
Old Jan 11, 2011 | 02:03 PM
Sorry, but the "butt force gauge" is about as accurate as the butt dyno. If you put these springs in a real force/deflection tester, you'll get the same curve of force vs. displacement with the tight coils oriented either way.
Old Feb 2, 2011 | 06:32 PM
DJS70cutlass's Avatar
The tighter coils go UP.
fixed
JPMDaddy
Jan 14, 2019 08:41 PM
rustycragars
Dec 25, 2016 06:06 PM
thomaswatk
Mar 22, 2007 01:31 PM
denis
Dec 22, 2006 05:03 AM
