Another steering box question.
Old Feb 21, 2020 | 08:20 PM
Fazer's Avatar
I want to put a fast ration box in the 69. I know the 93-96 Grand Cherokee boxes will work.That is one option and maybe the easiest.
I have also read that the box from an 83-88 Monte Carlo SS will work. Does anyone know for sure if it has to be from an SS Monte Carlo, or will any Monte Carlo do. I know some of the Firebird and Camaro will work, but that will be too hard to find cheap.
Old Feb 22, 2020 | 03:45 AM
deadeyejedi's Avatar
i believe speedway motors can supply you with a quick ratio box for your 69.if you go the 93 -96 cherokee route your steering shaft will need to be changed because the spline count is different on you 69 rag joint.as well as your power steering lines (if it is power steering ).this is generally a gbody swap but im sure it can be done with the 69 .There are experts here more qualified than i ,that can help with this .
Old Feb 22, 2020 | 07:57 AM
I recall the box from Speedway is the quick ratio option in the Lares brand that is a direct fit. Much better option than modifying one of those other boxes to fit.
Old Feb 22, 2020 | 10:07 AM
Cincinnati Rick's Avatar
Fazer,
Check out this link and make sure you know what you actually are trying to achieve. I was confused by the term "fast ratio" when I wanted to upgrade my box. You can also call the owner Marty at 417.374.7627 and he will answer any questions you may have. He's been doing these boxes for years and knows his stuff.I just got mine back from him but haven't installed it yet. If it performs as good as it looks I will be a happy camper.
http://www.powersteering.com/blog
AZ442
Suspension & Handling
141
Jan 20, 2020 03:49 PM
76olds
Dec 31, 2017 08:15 PM
Dead Reckon
Aug 18, 2015 08:56 PM
cheven
Aug 4, 2015 03:00 PM
Robert Kiedrowski
Jun 10, 2013 04:40 PM
