67 olds power steering leak
Old Jun 25, 2023 | 02:43 AM
Benny23's Avatar
Looking for help with leak at power steering it looks like it's leaking from the main line coming out of the pump not knowing what pump we have or if it's the right o ring any help thanks
Old Jun 25, 2023 | 06:09 AM
It's difficult to help without photos of what you have.
Old Jun 25, 2023 | 06:27 AM
Benny23's Avatar
I get pics after work today
Old Jun 25, 2023 | 06:49 AM
Benny23's Avatar
This one looks just like mine
Old Jun 25, 2023 | 06:52 AM
The Saginaw pump bodies are pretty much all the same. That is the correct reservoir for a 1967. There are three o-rings between the reservoir and the back of the pump - two small ones at the bolts and a larger one at the outlet fitting. There is also the large o-ring at the front of the reservoir where it seals to the front of the pump body.
Old Jun 25, 2023 | 06:55 AM
Benny23's Avatar
Thanks I think it's leaking out of the union I put a new one ring in there it's wet under there then drips down don't know if there supposed to be a washer too
aslockcuff
Nov 29, 2022 12:41 PM
Reese Neis
Jul 4, 2021 01:03 PM
rpinnt
Jul 20, 2018 10:49 PM
442iowa
Nov 6, 2017 05:28 PM
mid-life-olds
Apr 17, 2014 04:00 PM
