Looking for help with leak at power steering it looks like it's leaking from the main line coming out of the pump not knowing what pump we have or if it's the right o ring any help thanks
The Saginaw pump bodies are pretty much all the same. That is the correct reservoir for a 1967. There are three o-rings between the reservoir and the back of the pump - two small ones at the bolts and a larger one at the outlet fitting. There is also the large o-ring at the front of the reservoir where it seals to the front of the pump body.
Thanks I think it's leaking out of the union I put a new one ring in there it's wet under there then drips down don't know if there supposed to be a washer too
