1966 F-85 front coil springs
Old Aug 12, 2011 | 05:37 PM
doc's Avatar
doc
I have a sagging driver's front spring (about 2-3" lower than passenger) on my crew cab F-85 w/ a 330/auto.....I've already installed some new MOOG #6197 rear springs.
What would be a good front spring to buy that is firmer & a little lower than stock?
Thanks!
D
Old Aug 12, 2011 | 06:40 PM
Run to Rund's Avatar
You could try V8 AC coils. I have different 66 coils if you want to try some cheap.
Old Aug 14, 2011 | 04:51 PM
doc's Avatar
doc
I'll look into the A/C coils....any luck w/ those 15x8's or 15x10's?
Thanks!!
Old Aug 15, 2011 | 08:24 AM
copper128's Avatar
Lt. Buzzkill (ret.)
Use this table to compare springs once you determine your OEM replacement part number. You can check the height and rates to find something you like better.
http://www.moog-suspension-parts.com...il_Springs.asp
Old Feb 8, 2012 | 01:31 PM
doc's Avatar
doc
I went with moog 6310 springs up front....rides great, but is low.
Old Feb 8, 2012 | 09:15 PM
Those springs are 16.1" long. For the spring rate you chose, a 17" length would have probably been about right.
Old Feb 9, 2012 | 05:32 AM
doc's Avatar
doc
I bought these several months ago & finally put them in.....I have a set of four spc springs coming with my sc & c stage 2 plus kit. Changed directions on the car and it' s suspension.
It actually rides great with these springs......just has a super rake going on.
defiant1
Mar 18, 2010 06:43 AM
john suder
Nov 2, 2009 01:21 PM
Flye
Jun 12, 2009 01:21 PM
veltboy618
Mar 26, 2009 08:27 PM
mcutlass1969
Aug 6, 2006 03:47 AM
