1966 Cutlass/442 lower control arm question
Old Jul 25, 2022 | 10:47 AM
Fathers_Olds's Avatar
Hope everyone is safe and well!
Can anyone confirm the span between driver and passenger side rear lower control arm sway bar bolt holes on a 1966 442? Currently has stock boxed lower control arms with a Chevy 12 bolt. Would like to confirm distances for both front and back bolt holes. Appears to be approx. 38" span for front bolt holes and 40" for the rear. Purchased a solid 1964-72 aftermarket rear sway bar and it doesn't fit (38 1/4" front and 40 5/8" rear). Trying to verify if it's an issue with the car setup or the bar. Thanks in advance!
Old Jul 26, 2022 | 09:16 AM
nicks1966's Avatar
My 66 measures 38 3/8 front and 40 3/4 rear. With my distance your swaybar and one 1/16 shim on each side and it's a perfect fit.
Old Jul 26, 2022 | 07:28 PM
Thanks for the response and info.
AJFink
Jan 31, 2021 09:57 AM
Jon442
Nov 22, 2017 04:16 PM
Greg Rogers
37
Nov 7, 2014 07:39 AM
Charles Ludwick
Suspension & Handling
Mar 5, 2012 06:13 PM
crazy'boutOlds
Oct 4, 2011 05:45 PM
