Rear sway bar with unboxed control arms
Old Nov 22, 2017 | 01:42 PM
Jon442's Avatar
Gearhead
Supercars Unlimited has a kit to allow installing a 1" rear sway bar with unboxed control arms. The kit has spacers to keep the control arms from collapsing. Has anyone had experience with this?
Beyond the control arm question, is a 1" rear sway bar overkill on a Cutlass?
Old Nov 22, 2017 | 01:54 PM
RetroRanger's Avatar
72 Olds CS
probably will work OK, or they sell the piece to weld in into your LCAs to make them boxed
https://www.summitracing.com/parts/opg-rcai001
Old Nov 22, 2017 | 02:01 PM
70sgeek's Avatar
'72 Cutlass ragtop
I LOVE my 1" rear bar - combines nicely with the 1-5/16 bar I installed up front - '72 cutlass ragtop, My rear bar is connected to UMI Performance tubular control arms but I'd expect similar handling performance when tied to OEM-style arms as well (not sure about the non-boxed idea, though...)
Old Nov 22, 2017 | 02:31 PM
Just get boxed arms. The problem is that an open channel arm twists more than a boxed one. This twisting negates some of the added stiffness of the 1" rear bar, effectively making act like a smaller bar with boxed arms. If you plan to spend the money on an aftermarket bar, spend the extra $25 for the plates to box the lower arms.
Old Nov 22, 2017 | 04:16 PM
classicmuscle442's Avatar
You could also box your existing arms if you have a welder.
66-3X2 442
Mar 5, 2017 11:49 AM
66-3X2 442
Oct 4, 2011 09:13 AM
tdubis
Suspension & Handling
Jun 29, 2011 02:23 PM
JSGD1966
Oct 5, 2010 08:26 PM
Olds luvr
Jan 19, 2009 06:35 AM
