Axle Offset - Fix?
Old Sep 21, 2017 | 06:55 AM
Mark in MN's Avatar
Axle Offset - Fix?
The rear axle on my 68 98 (same four-link as a-body) is offset 1" to the right (clearance between fender skirt and tire is 1" less on right side). No evidence of collision damage, and new bushings were just installed and it made no difference. Is installing adjustable upper links a good way to fix this? Having it centered will provide more available clearance for wider rims and tires.
Old Sep 21, 2017 | 09:11 AM
Make sure its the axle and not the body.
Old Sep 21, 2017 | 10:31 AM
Mark in MN's Avatar
Good thought. I would rather move the body over half inch than anything else. Will try to get under it this weekend and see if that is possible.
Old Sep 23, 2017 | 09:05 PM
Mark in MN's Avatar
Body is offset.
Old Sep 24, 2017 | 06:37 AM
Originally Posted by Mark in MN
Body is offset.
You need to loosen body bolts and shift the body over to where it needs to be. Since your there, MAW see if the rubber mounts need to be replaced.
Old Nov 24, 2017 | 02:33 AM
cwb442's Avatar
How do you go about shifting the body over? Is there adjustability in body mounts?
Old Nov 24, 2017 | 03:52 AM
Loosen body bushing mount bolts and shift the body over the desired amount, its a good time to inspect/replace at this time. Its pretty easy with the car on a lift.
auto_editor
Jul 9, 2015 07:34 AM
65 Delta Guy
Dec 25, 2011 09:37 AM
my72vert
Jan 1, 2011 07:36 PM
Ranzan
Wheels and Tires
Jul 30, 2010 07:48 AM
1973olds98
Wheels and Tires
Jan 31, 2010 10:22 AM
