Axle Offset - Fix?
Axle Offset - Fix?
The rear axle on my 68 98 (same four-link as a-body) is offset 1" to the right (clearance between fender skirt and tire is 1" less on right side). No evidence of collision damage, and new bushings were just installed and it made no difference. Is installing adjustable upper links a good way to fix this? Having it centered will provide more available clearance for wider rims and tires.
