Comp Cam, part #42-229-4.
Old Apr 23, 2015 | 11:15 AM
marklt's Avatar
Hi al. a local supplier has listed a new olds 'performance cam' for sale. Ie got a 76 caddy,350 olds th400 stock. any ideas about what this cam might be...(ps im in the process of binning the old fuel injection setup and moving to a A4/ 4 bbl and headers)...
Oldsmobile 260-455 Hydraulic camshaft.
Operating range= 1500>5500 rpm.
Duration= 268 in & exh.
Valve lift .456" in & exh.
Cam only, NEW $100 obo.
Old Apr 23, 2015 | 02:23 PM
I just Googled it, and they describe it as a "hydraulic performance cam for mild street machines" with "broad power" and a "noticeable idle". Specs are:
Duration: 268 Valve lift: 0.456
Duration @ 0.050: 218 Lobe lift: 0.286
LS: 110
Single pattern, so intake and exhaust specs are the same. They say it makes power from 1500-5500RPM. Sounds like a nice mild street cam that might be compatible with a Cadillac.
Wait, you just said all that. What was the question?
Old Apr 23, 2015 | 06:11 PM
That cam seems short on either lift or duration, depending upon how you look at it.
My UltraDyne cam has 217º duration and .485" lift.
A Crane 260 cam has .456" lift and 204º duration.
So this cam has low lift and long duration (relatively speaking).
ericsolds
Oct 7, 2012 12:29 PM
BerBer5985
Sep 3, 2009 04:37 PM
MN71W30
Jun 23, 2009 07:24 PM
olds382
Nov 11, 2008 11:47 AM
