Distributer won't turn help!!
Old May 2, 2014 | 07:19 PM
76olds's Avatar
Hookers under Hood
Tried to set the timing today, loosened up the hold down and the distributer seems to be seized. Tried with a pry bar slightly but no go.
Old May 3, 2014 | 03:50 AM
76olds's Avatar
Hookers under Hood
I finally got it to move that bugger was tight!! Liquid wrench overnite and a baby pipe wrench did the trick. I have never had a distributer that was that stuborn. Anyone else have this problem? I didn't pull it but do you guys think its time for replacement?
Old May 3, 2014 | 04:08 AM
Beob's Avatar
I say if it ain't broke don't fix it.
Old May 3, 2014 | 04:11 AM
76olds's Avatar
Hookers under Hood
Cheers to that .
Old May 3, 2014 | 04:32 AM
Oldsmaniac's Avatar
Had an 85 Hurst with that problem. There is a rubber O ring on the shaft that gets stuck and also dirt and oil buildup there causes this. As long as its loose now you dont have an issue. It would just need a cleaning in that area and all would be fine.
5998DownUnder
May 9, 2016 01:51 AM
stevengerard
Sep 10, 2014 03:17 PM
H8D-67
Sep 16, 2013 01:19 AM
dennisspeaks
Sep 24, 2011 01:10 PM
mcutlass1969
Jan 1, 2007 11:15 PM
