Pulling the motor
Old June 24th, 2014, 12:20 PM
  #1441
Macadoo's Avatar
Originally Posted by VI Cutty
Looking sharp in there, Mac!
Is that battery tray just a bolt in replacement? No welding involved?
Sorry Cutty, I guess I didn't see the second half of your post. The tray came from thepartsplaceinc.com and is supposed to be an exact replica. I can't know for sure because mine was in rusty tatters. The new one looks good though and just bolts into place...if you can get the original bolts out. I actually had to grind the heads off and then drill them out.
Macadoo is offline
Old June 24th, 2014, 12:29 PM
  #1442
Hookers under Hood
76olds's Avatar
I think it will be money well spent having the shop fab up two front pipes, and get rid of those reducers, I had the shop here weld in box hangers and weld small rods to the pipe as well so that I had no universal hangers hanging down with clamps, makes it nice and tight.
Hopefully they will give you a couple options and prices.
76olds is offline
Old June 24th, 2014, 12:31 PM
  #1443
Senior Moment Member
z11375ss's Avatar
After. You at least need to be able to assess the job. Right? Thanks for the props on the vid.
z11375ss is offline
Old June 24th, 2014, 08:12 PM
  #1444
Justin
oldstata's Avatar
Mac , those craigers just set the car off !
I agree, I would have just towed the car in to the shop to have the exhaust done .
But job well done
oldstata is offline
Old June 24th, 2014, 09:47 PM
  #1445
Macadoo's Avatar
Irony, I'm all about irony. I paid like $180 for that entire exhaust system. It'll probably cost more than that for the down-pipes. Still, I was getting quotes of $700 and $800 dollars for an installed system, plus towing. And there's the bragging rights. But to be fair, it was pretty easy to install, the down-pipe snafu notwithstanding. The stock hangers were included, the holes were already in the frame (although some needed enlarging), and other the having to de-bur all the pipes, it was well made.
Glad you like the Cragars Justin. I was worried after I ordered them but nope, they're exactly what I wanted
Macadoo is offline
Old June 24th, 2014, 09:52 PM
  #1446
Macadoo's Avatar
True enough...true enough. I'm hoping they cut me some slack though. The pipes they bent didn't even come close to my mock-ups. Well, they were close, but way too long and I had to use strips of sheet metal because they swaged the ends too wide.
Macadoo is offline
Old June 25th, 2014, 10:05 AM
  #1447
RandyS's Avatar
Eerily quiet up in Illinois today.............
RandyS is offline
Old June 25th, 2014, 10:24 AM
  #1448
Professur's Avatar
When faced with irony ... it's best to give it a steely glare.
Professur is offline
Old June 25th, 2014, 10:39 AM
  #1449
Macadoo's Avatar
Yes, the quiet was a bad sign
We have a no-go condition for 1st start. After filling it with water and a little antifreeze I heard a funny noise. Check out this freeze plug.
[IMG][/IMG]
See the greenish stream? Maybe this happened during the engine install but I don't see how.
What is my fault is this leak at the water pump.
[IMG][/IMG]
I thought I did a good job sealing it up. I didn't glob the silicone on there but it was enough to squeeze out.
[IMG][/IMG]
Not the best day but I'll bounce back. I found adjustable freeze plugs at Napa and that seems do-able. Not relishing the thought of taking off the water pump though.
Macadoo is offline
Old June 25th, 2014, 10:42 AM
  #1450
Macadoo's Avatar
The rubber adjustable freeze plug says to install dry. Does that mean it'll just slide in or will it take some pounding? And any advice on getting the old one out?
Macadoo is offline
Old June 25th, 2014, 10:54 AM
  #1451
RandyS's Avatar
IF you can get at it, poke a bigger hole in it with a punch, then use a screwdriver or some such to pry it out. Looking at your pic, you could probably pound a new metal one back in the hole, then paint it? If not, the rubber one should go right in and enlarge to seal the hole as you tighten the nut.
I use the black stuff on the water pump and neck.
Just put plain water in to start with, easier to clean up and cheaper if you have to drain it.............
RandyS is offline
Old June 25th, 2014, 11:23 AM
  #1452
Macadoo's Avatar
Yeah, my overconfidence got the best of me. I'm just glad I only put in half a gallon.
The adjustable plug won't look as good, true, but I don't have room to properly pound in a new one, I don't think. Cheap enough to try I guess. Silicone on the metal plug?
I can't remember if I used the black silicone or gray. Either way, I'm using more this time.
Macadoo is offline
Old June 25th, 2014, 11:36 AM
  #1453
Professur's Avatar
Don't wuss about. You don't even have rusty exhaust bolts to deal with. Yank it back out and fix it right. Won't take more than a couple of days.
Old June 25th, 2014, 11:58 AM
  #1454
Macadoo's Avatar
I gave myself an hour to wuss about. Now I'm back to work. Not pulling that engine back out quite yet. I think I can do what needs to be done without all that hassle.
But thanks for the kick in the pants
Macadoo is offline
Old June 25th, 2014, 12:24 PM
  #1455
Professur's Avatar
You can always do what I do ... give it to the kids to solve. They don't often get the job done, but I'm always impressed at some of the methods they attempt.
Seeing that stream of **** ... that had to be heartbreaking.
Old June 25th, 2014, 02:50 PM
  #1456
Macadoo's Avatar
A little heartbreaking, yes. I just can't figure out when it happened...and if I'm looking at the others relieving themselves.
It's being stubborn but I'll get it eventually. The fam is going out of town tomorrow so I'll have a few days to swear and throw tools
Macadoo is offline
Old June 25th, 2014, 03:22 PM
  #1457
mrolds69's Avatar
Getting the plug out is pretty easy, poke a hole in it and lever it out. Snap-on and others make a tool for installing a plug on an engine in the car. It has like a round disc to fit the plug, and a long handle at an angle to beat it back in. You can probably find a pic on the Snap-on website if they still make it. Could whip one up if you are handy. It almost looks like your plug is in too far. A tool like this...
Amazon.com: OTC 4603 Frost Plug Remover and Installer Set: Automotive Amazon.com: OTC 4603 Frost Plug Remover and Installer Set: Automotive
mrolds69 is offline
Old June 25th, 2014, 06:59 PM
  #1458
Macadoo's Avatar
Originally Posted by mrolds69
Getting the plug out is pretty easy, poke a hole in it and lever it out. Snap-on and others make a tool for installing a plug on an engine in the car. It has like a round disc to fit the plug, and a long handle at an angle to beat it back in. You can probably find a pic on the Snap-on website if they still make it. Could whip one up if you are handy. It almost looks like your plug is in too far. A tool like this...Amazon.com: OTC 4603 Frost Plug Remover and Installer Set: Automotive
Everything I read on the internet said the same thing. But I found it anything but easy. That sucker was welded in there or something. I finally got it broke loose. But it was fairly prestine, no rust. I can't imagine how it got a hole in it.
Tomorrow I start removing accessories and getting to that water pump. But before I do, I had another look at my water pump install pictures and I don't see how it could have leaked. I'll look around and make sure it didn't come from somewheres else, first.
Macadoo is offline
Old June 26th, 2014, 01:15 PM
  #1459
Macadoo's Avatar
Update: I got the new core plug in, I used one of the rubber deals because I was ready for a little "easy".
I pulled off the water pump and something seems very odd to me. I have the old install pic and I remember coating one side of the gasket with rtv, applying it to the front cover, and covering the other side of the gasket with rtv.
[IMG][/IMG]
But the pump pulled off wayyy too easy...and the gasket was still blue...and wet. And there was hardly any rtv to be seen. This is a pic of the pump before I cleaned it (I think I pulled off one small string of rtv before the pic).
[IMG][/IMG]
The front cover was fairly clean as well and needed very little scraping. The gasket pulled off in about three pieces and left a few small strings of rtv but that's it. Very strange.
However, that not withstanding, you can see in this pic why the pump was leaking. If the paint pattern is correct (I painted the block after installing the pump) then the gasket didn't match the sealing surface of the pump. And that's odd as well as I remember checking. I had three different gaskets and I matched up what I thought was the best one. Guess I was wrong.
[IMG][/IMG]
Anyway, just some interesting notes. I have a new tube of black rtv but I have to wait until tomorrow for the gasket(s) to come in to my local Napa. Then I'll get 'er back together.
Macadoo is offline
Old June 26th, 2014, 04:18 PM
  #1460
RandyS's Avatar
You must have gremlins......... a hole in a new freeze plug, and a gasket that matched before assembly but didn't seal.......... (Is your address 666?). Better luck next go-round.
RandyS is offline
Old June 26th, 2014, 04:22 PM
  #1461
Sampson's Avatar
Mac, I gotta wonder about the working time of the RTV before it was bolted together. Usually using this stuff on both sides of the gasket is a bear to clean up. Or could there have been a preservative on the pump to keep it from rusting that also kept the RTV from sticking? Others with more knowledge may be able to help more. Anyway I have been there done that. We all go through this stuff
Sampson is offline
Old June 26th, 2014, 04:49 PM
  #1462
Wow. Sounds like you're workin' with Mr. Murphy.
Let's hope he clocks out early so you can get this done!
MDchanic is offline
Old June 26th, 2014, 05:03 PM
  #1463
Hookers under Hood
76olds's Avatar
I normally just use rtv on the water pump then fix the gasket to the pump, then a very thin layer just around where the bolts go on the cover, as well as the thermostat housing. The rubber bung you bought should work well if it has the wing-nut to tighten up in the hole. Tryin to put it out their as clean as I can ya know guys!!. Ya so once you get that rubber in the hole dry giv-er a good few twists it will expand out nicely. then It can get as wet as it wants no leaks their.
I'm feelin your pain on this deal, hope you have better luck on the second round fire up.
76olds is offline
Old June 26th, 2014, 05:35 PM
  #1464
Macadoo's Avatar
Aha, I think you just solved the mystery Sampson! I was about to say that i cleaned everything with brake cleaner, and I did. But I also cleaned around the installed pump with break cleaner. I now remember thinking that paint won't stick to silicone so I'd better clean the excess before it cures. I might have been a little over zealous with the cleaner, which would be very characteristic for me. I don't think I sprayed it directly onto the cover but it's possible.
Mystery solved!
The plug had a nut that was quite easy to turn. I'm confident that it sealed up nice and tight.
Macadoo is offline
Old June 26th, 2014, 07:36 PM
  #1465
Justin
oldstata's Avatar
Mac sorry about your gremlins. They tend to hide in the garage the most.
Did you have it running when you found these leaks ? If so did you finish breaking in the cam before shutting it down ?
oldstata is offline
Old June 26th, 2014, 08:06 PM
  #1466
Macadoo's Avatar
No Justin, I was preparing for the big 1st start. I was filling the radiator when I felt my toes get wet
It threw me for about an hour but I'm in a good place now. Hey, after I re-install the pump, how long should I wait to start it? Hours or overnight? I'm not in a hurry, just, you know....
Macadoo is offline
Old June 26th, 2014, 08:13 PM
  #1467
Justin
oldstata's Avatar
That's good that it wasn't running my luck it would have been two min into it
Pump / over night is good but to be honest, I have started them up after install and been fine.
I did my 72 cutlass in auto zones parking lot in 2003
oldstata is offline
Old June 26th, 2014, 08:52 PM
  #1468
Macadoo's Avatar
Lol, in the parking lot? I take it a water pump isn't one of those parts they install for free.
I'll give it a few hours at least, if not overnight to be safe.
Macadoo is offline
Old June 26th, 2014, 09:04 PM
  #1469
Justin
oldstata's Avatar
Yes, in there parking lot I had to leave my ID to use there little tool bag of the worst tools ever to do the job.
oldstata is offline
Old June 26th, 2014, 09:19 PM
  #1470
Macadoo's Avatar
Lol, I'm impressed.
Macadoo is offline
Old June 27th, 2014, 07:10 PM
  #1471
Macadoo's Avatar
Okay, I pulled the water pump and replaced the gasket. I definitely used the wrong gasket last time. I also pulled the bypass neck and replaced that gasket just for good measure. I used more silicone this time which took about an hour and thirty-some DRY q-tips to clean up the excess.
Then it was paint time....
[IMG][/IMG]
It's all back together now and I'm hoping for a first start tomorrow...
[IMG][/IMG]
...but I've learned not to make any promises
Macadoo is offline
Old June 27th, 2014, 07:25 PM
  #1472
Fingers crossed.
MDchanic is offline
Old June 27th, 2014, 07:27 PM
  #1473
Macadoo's Avatar
Originally Posted by MDchanic
Fingers crossed.
Thanks dude
Macadoo is offline
Old June 28th, 2014, 03:36 PM
  #1474
Macadoo's Avatar
It's alive! It'e alive!!!
Lol, sorry, cliche I know but I couldn't resist, and I boogered the title anyway, lol. Admin?
It wouldn't start at first so I was thinking I had the #1 on exhaust maybe? But Randy and [other]Eric set me straight. I tried advancing it a little more, then retarding it a little and she fired right up. Ran up front and cranked up the idle to about 2300 and let it rip, lowering and raising the idle a little now and then. Tons of smoke out the tail pipe (Eric-chanic suggested adding oil to the cylinders), and even more from the engine bay (stove black paint on the headers), puking water until the air pockets relieved themselves, and I tried adding trans fluid with a strong breeze blowing in the window (I needed to clean my windshield anyway), had all the doors and windows open but I still choked on fumes but it's running!
Now, it's time to tune. And I think i may have fried my trans. I got to the fluid as soon as I could but it takes a second to kick into drive and reverse. And starting from a standstill it feels like parking brake is dragging...or maybe the regular brakes....but it's running! And I want an R4 anyway.
Macadoo is offline
Old June 28th, 2014, 03:55 PM
  #1475
Justin
oldstata's Avatar
Way to go Mac
Check your trans fluid again make sure it's topped off
oldstata is offline
Old June 28th, 2014, 04:08 PM
  #1476
Chevy budget Olds powered
coppercutlass's Avatar
Congrats buddy ! Now time to put in some 3.23 's and haul some *** lol. sounds good. car looks sharp kudos on the tire combo . Just right imo .
coppercutlass is offline
Old June 28th, 2014, 04:18 PM
  #1477
Wtg, high five, congrats, ok enough of that. Wheels and tires look great! Check your trans level as stated previously, get it tuned, straighten out your tailpipes, check your brakes, and go for a ride.
oldcutlass is online now
Old June 28th, 2014, 04:23 PM
  #1478
RandyS's Avatar
As Freddy Prinze would have said - Hey Man, Jew are Loooookiiiiiing Goooooood!
Sounds sweet! Congrats!
RandyS is offline
Old June 28th, 2014, 04:45 PM
  #1479
morgan
pogo69's Avatar
Pat yourself on the back...nice accomplishment, enjoy
And the tranny will be fine
pogo69 is offline
Old June 28th, 2014, 05:22 PM
  #1480
Macadoo's Avatar
Way to go Mac
Thanks Justin!
Or 4.11s? Lol, 4 speed trans first. Thanks dude.
Thanks Eric. I went for a couple of short rides but the downpipes are scraping on the road if I hit a small bump. The next ride will be to the muffler shop.
ROTFL! Thanks Randy.
A pat on the back and a good night's sleep. It's been a while. Thanks for the thumbs-up Pogo.
Thanks for all the help everyone! I'm sure I'll have a lot of questions about tuning.
Macadoo is offline
Quick Reply: Pulling the motor
