1970 cutlass running, sound good or no?
Old December 4th, 2012, 01:42 PM
1970 olds cutlass supreme
rocket350's Avatar
http://www.facebook.com/photo.php?v=3990124439449
this is my facebook and my cutlass running, what do guys think? need work or does it sound ok?
this is after 15 yrs sitting with just new spark plugs
rocket350 is offline
Old December 4th, 2012, 02:56 PM
The_Jeremiah's Avatar
unless it has a very hot cam, it needs a little work. I would drain the gas out of the tank and clean the tank, blow the lines out, replace fuel filters, definantly pull carb apart and see if anything is left. make it nice and clean inside. I hope you pre oiled the motor before you got it running, ive seen engines go as far as bend pushrods from not being oiled after sitting for years and starting them up
The_Jeremiah is offline
Old December 4th, 2012, 03:08 PM
rocket350's Avatar
yea im gonna try to get around to the fuel system this weekend.
what should i use to clean out the tank?
Old December 4th, 2012, 07:46 PM
General Confusion
Nunyadam Biz's Avatar
Pull the carb apart = rebuild the carb. not a bad idea. (but do a tune up first.)
the car will need a full tune up cap, roter, wires. oil change and all.
might not be a bad idea to run some Seafoam or marvels mystery oil through it before you change the oil. (years ago I would have put a quart of kerosene in it for a few minutes before the oil change.)
it doesn't sound to bad for sitting that long, for now K.I.S.S it (keep it simple stupid)and stick to the basics.
Nunyadam Biz is offline
Old December 5th, 2012, 12:10 AM
rocket350's Avatar
i heard that seafoam was bad for the car?
Old December 5th, 2012, 05:25 AM
Lansing built
1970cs's Avatar
Someone mentioned tuneup but no points and condensor replacement?
Hard to tell from video whether it has the original setup. Also set timing and dwell if it still does.
Pat
1970cs is offline
QS442
June 30th, 2015 04:17 PM
Carl, uk
March 13th, 2014 05:43 AM
Bill in NC
September 27th, 2011 05:38 PM
BStone
August 23rd, 2011 06:18 AM
christl
May 26th, 2009 06:33 PM
Quick Reply: 1970 cutlass running, sound good or no?
