slow starter
Old Jul 28, 2007 | 06:25 PM
ztim's Avatar
slow starter
My '84 88 takes longer to start if it was sitting overnight. It usually takes three tries. Does the gas drain back a ways and it takes longer for the fuel (pump?) to get back up to the carb?
Old Jul 28, 2007 | 06:49 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Hmm... It's always been 2 pumps of the gas pedal and 1 crank to start my 85 for the last 9 years unless it sat for more than 2 weeks. See if you have any vacuum leaks, bad egr, and vacuum test your choke controller. your choke butterfly may be sticking or hanging up as well.
Old Jul 28, 2007 | 06:51 PM
if It's a diesel that's a different story. Weak glow plugs maybe.
Old Jul 30, 2007 | 03:01 PM
don71's Avatar
same but different
Are you using the factory fuel filter? It has a anti-drain back function.
But usually the main wells are porous and leak fuel. A little epoxy works here, but requires removel and dissassembly of the carb. I've tried to link a photo of what I'm referring too. If it doesn't work go to my gallery.
https://classicoldsmobile.com/forums...00/ppuser/5845
Old Jul 30, 2007 | 06:13 PM
Oldsguy's Avatar
Past Administrator
Don, you have some good pictures in that gallery, Nice work on the '71 too!
Old Jul 31, 2007 | 12:45 PM
ztim's Avatar
Thanks Don71. I just put a new filter in it a few months ago. Picked it up at Advanced. I'll bet it is draining back somehow. I won't worry about it for now. The few extra seconds starting is no big deal. The pics were great.
wolfman98
Site Help
Nov 19, 2009 05:06 PM
a64olz
Apr 22, 2009 07:55 AM
a6m5zerosen
Jan 11, 2008 08:29 PM
bandit600
Nov 15, 2006 06:24 AM
69olds350
Nov 7, 2006 07:01 AM
