Slow current drain running down battery...
Old Jan 11, 2008 | 02:33 PM
a6m5zerosen's Avatar
1977 Cutlass Supreme
I have an '85 Custom Cruiser. It has a brand new battery, but when left unstarted for a few days the battery will go dead. I have checked and made sure the dome lights aren't staying on, etc. Years ago I remember hearing about a troubleshooting method involving a test light and pulling one fuse at a time to find which circuit the problem is in. Anybody familiar with this method, and if, so, what's the correct procedure? Thanks for any help with this.
Old Jan 11, 2008 | 08:29 PM
ozoneblue's Avatar
Wink Battery drain
Yes.I do this all the time except I use a old seat belt buzzer instead of light .Use a regular test light not the Snap On version with fuse looking bulb. Takes too many Amps. Disconnect neg cable & connect light between cable & Battery post.With key off & door closed light should not light, If it does start by removing courtesy light fuse first & re check light, then try each fuse one at a time.If you still show drain disconnect plug at alternator. then battery+ at alt.You have just about covered all the system except a bad cell in the battery.Thats a different test Good luck & keep us informed. The reason I use a buzzer is because it easier to hear than crawling out from under the dash each time to see if the light went off. Larry
Arrowstorm
Aug 9, 2015 04:27 AM
Texas442
Mar 28, 2013 07:13 PM
aristellier
Sep 9, 2012 03:49 PM
wolfman98
Site Help
Nov 19, 2009 05:06 PM
a64olz
Apr 22, 2009 07:55 AM
