help priming oil pump on 350
Old Mar 20, 2011 | 06:11 PM
84oldsDelta88's Avatar
Since its been sitting for 10 years I changed the oil and filter today, I cranked the engine over with dist. disconnected and I didn't see any oil getting to the lifters. I'm wondering if the oil pump is maybe shot. Is there another way to prime the oil pump besides removing the dist. If the only way to prime it is by removing the dist. what can I use to spin the oil pump does a socket fit? Moneys tight cant afford the special tool for this at the moment.
Old Mar 20, 2011 | 06:36 PM
Nor Cal Andy's Avatar
Hey I just used a quarter inch drive socket with a long extension in a electric drill. You have to pull the distributor first. I did it for quite a while and made sure oil was flowing through every passage..
Andy
Old Mar 20, 2011 | 07:47 PM
Duct tape the socket to the extension - wouldn't want to lose it...
Old Mar 21, 2011 | 06:50 AM
Also, be sure you're turning in the correct direction (CCW).
This oh so helpful site has it wrong:
http://boxwrench.net/specs/Olds_Gen_2.htm
Old Mar 21, 2011 | 07:53 AM
Beob's Avatar
You should also fill oil filter first, it will get oil flowing much quicker.
Old Mar 21, 2011 | 01:25 PM
Thanks for the info, i tried what you guys said i pulled the dist. used a 5/16 socket with adapter for the drill. Must of been drilling for a good minute or so, with valve cover off looking for oil but i got nothing, it put 1 hell of a load on the drill through. So i'm guessing by that, that means the oil pumps shot right? I cant think of why else it wouldn't been pumping oil to the valves. Advance auto wants $32 for the pump and then $16 for the pump screen. does that seem about right or does someone carry it cheaper. How hard is it to change an oil pump i know i have to drop the pan to get to it but i dont know what tools i need, or if i need to set the new one a certain way. Can i change out the pump while the motors in the air hanging from the engine crane? thanks for all the help, I know ol' betsy appreciates it.
Old Mar 21, 2011 | 02:03 PM
Pull a few of the pushrods and run a wire through each to verify that they are not clogged.
Old Mar 21, 2011 | 02:39 PM
Bluevista's Avatar
Registered
Dang!!!
I wondered why my engine was running backwards!
A little knowledge really is a dangerous thing.
"Ignore Alien Firing Orders"
Old Mar 21, 2011 | 06:11 PM
tinner's Avatar
Sometimes it can take a while. Listen to what Joe is telling you. Odds are that you just need to spend a little more time on it. Good luck!
Old Mar 21, 2011 | 06:21 PM
Well it was stressing the drill I borrowed to the point it was smoking and its a powerful drill I'll tell you what. I did notice that when I would stop the drill I would hear a faint (errrrr) sounding squeak coming from the engine near the oil pump area.
Odmark
Jul 28, 2013 04:31 PM
Olds Scott
Mar 11, 2013 07:30 AM
JRios
Sep 29, 2010 08:39 PM
dallasite21
Aug 31, 2010 07:54 AM
Wasted
Nov 22, 2008 05:59 PM
