Replacing Valve Cover Gaskets
Old Mar 18, 2011 | 01:37 PM
70Cutlass_408's Avatar
I was told that my valve cover gaskets need replacing. Is this something a person with no real mechanical knowledge can do. I have changed spark plugs in the past but nothing major.
This is for a 1970 Cutlass Supreme w/350 Rocket (has Air Conditioning)
Thanks Guys!
Old Mar 18, 2011 | 02:57 PM
TripDeuces's Avatar
Should be easy for you. Your biggest challenges are the brackets over the valve covers. You'll have to get them out of the way to remove them. Once out of the way you have 10 bolts on each side, no biggie. Best time to get your feet wet before bigger projects come up. Pretty straight forward stuff
Old Mar 18, 2011 | 03:03 PM
It's not hard, just time consuming. A decent set of hand tools and a sailers vocabulary will work!!!
Old Mar 18, 2011 | 03:17 PM
thanks guys, I'm going to give it a try this weekend, Thanks for the confidence booster.
Old Mar 18, 2011 | 03:22 PM
Rickman48's Avatar
Take pictures before starting, for reference!
Old Mar 19, 2011 | 04:23 AM
My442's Avatar
Use FelPro PermaDry gaskets.
You will never change them again.
Old Mar 19, 2011 | 05:02 AM
jozw30's Avatar
x2 on the Permadry!!
Good stuff.
Clean the surfaces really good too.
Old Mar 19, 2011 | 06:12 AM
MHENDERSON's Avatar
One of the best things I use to clean them up is paint thinner!
Old Mar 19, 2011 | 06:58 AM
And don't overtighten the little attaching screws!
Old Mar 19, 2011 | 07:18 AM
Nilsson's Avatar
Excellent advice do not over tighten.
Tighten to 7ft pounds starting with the center screws. Then after a couple heat cold cycles retorque. They won't leak again for years if
this process is followed.
Old Mar 20, 2011 | 08:36 PM
Well I managed to replace the valve cover gaskets without to much trouble, just took more time than I expected. I noticed this green wire with a burnt connector tucked under the carburetor on the passenger side. This green wire was disconnected. What is it and where does it go. I have a Rochester quadrajet carb.
Thanks again
Old Mar 20, 2011 | 08:47 PM
Is it the wire for the electric choke that's next to it?
Old Mar 20, 2011 | 08:53 PM
The green wire was tucked under the electric choke and it doesn't look like it connects to the electric choke.
Old Mar 20, 2011 | 09:01 PM
The plug itself looks like the plug for the A/C compressor, but it's usually one black and one green wire, and the black one goes right to ground. There should be no superheat switch on a '70, so no weirdness with the A/C wires.
You got me.
Old Mar 21, 2011 | 05:22 AM
Lady72nRob71's Avatar
DO use the permadry+ gaskets!
If you do not have a torque wrench, use a nutdriver and tighten them by hand. - That will be close.
That wire looks similar to that of the TCS solenoid (which if you still have it, it would be threaded in the intake next to the oil fill tube.)
That resistor kinda gives it away...
The TCS is an emission device that is frequently bypassed.
Old Mar 21, 2011 | 11:53 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Definitely looks like the A/C compressor connector. Block the hot air tube inside the housing and run a 12V key on wire to your electric choke.
Old Mar 21, 2011 | 09:31 PM
Should I replace the choke and connector. And if so where does the "pig tail connector" connect to. One end to choke and the other end to ??
Thanks,
Ddbord
Apr 12, 2012 06:50 PM
Aceshigh
Mar 27, 2010 08:36 AM
miho35o
May 24, 2009 04:32 AM
miho35o
Mar 28, 2009 09:41 PM
dallas6778
Nov 20, 2007 10:04 AM
