1972 olds 350 engine help
i had the same problem with my 330, i took a propane torch and heated it red hot and gently tapped on the "pressure fittings" evenly around to make them smaller and re-tempered the steel to make sure i didn't weaken it too much, looks ugly but fit..where are you located? i took out the 330 and if you're near by you can have it for free. it took about five tries because i couldn't figure out how to make steel larger(lol) but checking the fitting again and again and it worked fine.
i'm sure it obvious but i failed to mention thats what i did for the dipstick :-P
1973Omegaman
November 7th, 2014 07:28 AM
