1972 olds 350 engine help
Old March 21st, 2011, 01:14 PM
http://www.youtube.com/wa
theoldsrocket's Avatar
I need to identify if my block is correct for the year.
Block# 395558 with 7A heads
Are the 7A heads correct for 1972? thanks
theoldsrocket is offline
Old March 21st, 2011, 02:05 PM
7A heads (upper case "A" that's smaller than the "7") are correct for 1972. Beware of 7A heads where the "A" is the same height as the "7". Those are the peanut port heads from the late 1980s 307s.
joe_padavano is offline
Old March 21st, 2011, 03:07 PM
Thanks I'm sure the A is lower then the 7.
Old March 21st, 2011, 03:08 PM
Also I got my broken dipstick out and now my after market chrome one won't fit, should I trim the chrome off?
Old March 21st, 2011, 04:22 PM
oldzy's Avatar
Here are my stock 7A 350 heads off my 1972.
oldzy is offline
Old March 21st, 2011, 07:03 PM
those are the same as mine in the picture thanks
Old March 21st, 2011, 07:57 PM
anyone know about the dipstick?
Old March 21st, 2011, 08:04 PM
Lalo442's Avatar
I had the same problem with my 69 350 had to grind lightly around the chrome dipstick to get it in I think mine is a Transdapt dipstick but finally made it in with some persuasion
Lalo442 is offline
Old March 21st, 2011, 08:55 PM
Yeah mines transdapt to so I got it in now it just won't lock into place. PLEASE HELP.
Old March 21st, 2011, 09:12 PM
Lalo442's Avatar
It has to be a tight fit I think I used a 2X4 on the top end and tapped it until it it reached the ridge where it bottoms out sticks in pretty good ....hope it helps ...
Lalo442 is offline
Old March 21st, 2011, 09:15 PM
oldzy's Avatar
Banging a dipstick in from the top never worked for me. I had to use channel locks, needle nose pliers or similar on the lip near the bottom, and tap on the pliers to get it in.
oldzy is offline
Old March 21st, 2011, 09:43 PM
Still no luck I tried everything, only thing I banged was my thumb.
Old March 21st, 2011, 11:27 PM
JeremyTA's Avatar
i had the same problem with my 330, i took a propane torch and heated it red hot and gently tapped on the "pressure fittings" evenly around to make them smaller and re-tempered the steel to make sure i didn't weaken it too much, looks ugly but fit..where are you located? i took out the 330 and if you're near by you can have it for free. it took about five tries because i couldn't figure out how to make steel larger(lol) but checking the fitting again and again and it worked fine.
i'm sure it obvious but i failed to mention thats what i did for the dipstick :-P
JeremyTA is offline
1973Omegaman
November 7th, 2014 07:28 AM
Itza55
January 26th, 2014 04:13 PM
JoeKraus
May 29th, 2011 05:44 PM
ROCCETMAN
October 20th, 2009 06:04 PM
dharlett
September 23rd, 2009 03:30 PM
Quick Reply: 1972 olds 350 engine help
