i know..... another transmission leak question
Old September 17th, 2010, 12:37 AM
Good_Music_n_Cars's Avatar
dont hate me now, i got another transmission leak question here
ok so i put a shift kit in my turbo 350. (71 cutlass) it leaked before. no that bad though tool months to get a couple drips. now..... shoot it leaks like crazy but this is the thing. if i drive the car, its dry as a bone. then i park it and it sits for 6 hours and here it comes....... i have put 4 different gaskets and changed the pan. also tried high heat gasket sealer (wortha shot). seem to be coming from the pan bolts in the front under the fly wheel. i dont see and leak from above at all. any suggestions? and help is much appreciated ! GOD BLESS
Good_Music_n_Cars is offline
Old September 17th, 2010, 01:04 AM
davesdelta's Avatar
I`m no mechanic but it really sounds like a bad front seal...Could be anything else though, I suppose.
davesdelta is offline
Old September 17th, 2010, 07:44 AM
citcapp's Avatar
Silly question but did to flatten the lip of the pan at the bolt holes to get rid of any dimples before installing the pan?
citcapp is offline
Old September 17th, 2010, 08:09 AM
well there was no dimples around the bolt holes. it's flat around the holes then there's a 2 inch dimple between the bolt holes. can I ask why u asked that? curious
Old September 17th, 2010, 08:12 AM
did I read u right? are u talkin bout the lip of the pan or the raised dimples that are between the bolt holes that press the gasket down?
citcapp's Avatar
quite often the pan bolts are over torqued causing the pan to dimple into the gasket, the when re-installed the the dimples hold the pan from sealing against the gasket. Hence a leak occurs
citcapp is offline
Old September 17th, 2010, 08:18 AM
ok it is kinda a cheap pan. it was all I could find locally. but all in all the damn thing doesn't leek until hours after the car is sitting. there's not a drip when the car is on the road. if there was a leak in the pan wouldn't it leak either way? should I try another pan? when I put it on the ground face down it does wabble a tad cause it's not flat? how tight should the bolts be. 10 psi right
Old September 17th, 2010, 08:32 AM
Shizzy's Avatar
pull the inspection cover for the converter and see if you can see if the fluid is leaking down from the front pump seal.
You are probably just seeing it as it drips down far enough to look like a pan leak.
Shizzy is offline
Old September 17th, 2010, 09:37 AM
yeah i did that dont see nothin there.
Old September 17th, 2010, 09:40 AM
can anyone recommend a pan and gasket that help them with there leaking 350? are moroso gaskets worth the 32 dollars?
Old September 17th, 2010, 10:51 AM
this is not my car lol
scubastever's Avatar
the biggest mistake people make when resealing a pan gasket is forgetting to clean the bolt holes and bolt ends of residue silicone.
when you retorque those bolts, with silicone in the holes, you end up with a lower clamping force applied to the pan & gasket.
so guys (and gals),
please clean your bolts and your holes !
scubastever is offline
Old September 17th, 2010, 11:13 AM
Be careful using silicone on a transmission pan gasket. If it oozes out on the inisde of the transmission it can work free and cause damage to your valve body. I've never had to use RTV on a transmission pan gasket before, and they always seal well. I am with Pat on this one. Ensure your pan is flat and then install the pan to the proper torque with the gasket.
Olds64 is offline
Old September 17th, 2010, 01:41 PM
jeffu231's Avatar
If it is on the passenger side, it could be either the dipstick tube or where the downshift cable goes in. They are just above the pan area and if leaking can make it look like a pan gasket. Also after sitting the oil in the transmission will rise as it drains back to the pan and thus raising into the area where it can leak from these two areas. They both have a simple O ring to seal them.
jeffu231 is offline
Old September 17th, 2010, 06:33 PM
thanks everybody. ima clean it up real good with brake cleaner and watch it all day fro the exact leak. i got a lil dental mirror to check in hard to see areas. yes jeff i change the orings there already but thanks alot bra. i will get dirty tommorow for the last time findin the damn leak! hahahahah ! good night God Bless
Old September 18th, 2010, 04:34 AM
Shizzy's Avatar
X2 on the dipstick tube area.
Shizzy is offline
Old September 19th, 2010, 07:26 PM
GM Enthusiast
OLD SKL 69's Avatar
That's the best way to do it. Leaks like that can travel around. Good luck.
OLD SKL 69 is offline
Old September 20th, 2010, 03:10 PM
ok so after my lil mirror came in handy its definitely the front seal leaking. i didnt know if i should make different post for this but my question now is........... taking the trans out? its a turbo 350, any certain bolts to start on first? any tricks of the trade u seniors can hand down to a freshman? LOL...... while the transmission is down, i will change the front and real seal. anything else u would recommend? thanks for the info gents! GOD Bless
Old September 20th, 2010, 03:26 PM
Grown Azz Kid
Olds luvr's Avatar
Well I just had mine out, not too hard to do. Although my leak is now from the kick down cable and driving me nuts. make sure the car is high enough to get the trans out from under if you are on the floor. I have a trans jack and the trans on the jack did not fit under the car. The 2 top bell housing bolts I did from up top and the middle 2 and lower 2 from the bottom. Long extensions and wabbles will help you out. I also used big wood blocks to prevent the engine from tilting backwards but do not know if that was needed
Olds luvr is offline
Old September 20th, 2010, 11:11 PM
kick down cable? is that an o ring? should i change that while its out? also how did u get the car high enough. what did u put it on? thanks bra !
Old September 21st, 2010, 08:35 AM
Grown Azz Kid
Olds luvr's Avatar
I would change the o ring for the cable and the dipstick tube while it is out. Make sure you disconnect the cable at the gas pedal and undo it from the firewall so the cable stays in the trans when you remove it.
I had the car on jackstands, then had to take the trans off of the jack to slide the trans out from under the car. Then putting the trans back in I had to slide the trans under the car and then put it back on the tranny jack. maybe my jackstands are shorter but they are 3 ton, maybe the 4 ton are higher.
Old September 21st, 2010, 04:38 PM
cool man thanks alot! is there any pattern of bolts to start with first? can anyone chime in in that?
Old September 21st, 2010, 08:29 PM
Grown Azz Kid
Olds luvr's Avatar
Do the top 2 from the engine compartment fisrt before you put the car in the air. The dipstick tube for the trans is bolted to one of the bell housing bolts anyways. drain the trans before removing the dipstick tube. So basicly, lift the car, drain the trans, drop the car to get the top 2 bell housing bots (do not need to drop it but I did to make it easier) Then get the car up on all fours, middle and bottom bellhousing bolts and have at it. there are 4 bolts in the cross member and 2 on the trans mount. get a factory manual it will help. I have the factory and the cheaper haynes manual
Old September 21st, 2010, 09:56 PM
coolio !!! thanks alot brotha ! God Bless
Old September 23rd, 2010, 02:51 PM
ok one more question. not only is the front seal leaking but, it looks like i have a small leak on the passanger side of the transmission. i believe called the accumulator? its that 2 1/4 inch circle on the pass. side of trans held by a snap ring? am i right in saying this? its not the downshift tube or the dipstick. i changed bot the O rings there . as far as the accumulator goes.........is that a gasket change or an O ring?
ominayak83
April 18th, 2013 10:55 AM
1965cutlassragtop
April 3rd, 2011 07:01 PM
442garage
May 13th, 2010 09:22 AM
thatguy32567
August 2nd, 2009 06:12 PM
Quick Reply: i know..... another transmission leak question
