Chunk blown out of exhaust manifold gasket
I replaced the heads earlier this year, but it didn't occur to me to resurface the exhaust manifolds so I found it not sealing correctly. I realized I happened to have a set of exhaust manifold gaskets I got just in case, so to get the car back on the road quicker I just used those. It worked great until just a short time ago when I noticed header noise. It was pointed out to me that there was a manifold leak, and looking at it I saw a chunk of the gasket missing, and we're talking about thick metal gaskets. I wouldn't believe it if I didn't see it for myself. Does anyone have suggestions on how this could have happened?
This was the fix we used years ago in shop, I apprenticed in. Anytime an Olds V8 came in with leaking exhaust manifolds, we installed a gasket and away they went. It may be a warped manifold or a shitty gasket. We never had one come back that I recall.
SCE, specifically it was this one which seems to no longer be available and is superseded by a new model which looks the same. It looked really good on the outside, metal, nice and thick.
The manifold is definitely warped, both of them are. The new heads were fully rebuilt stock (the old ones were shot) and the initial reinstallation produced significant exhaust leaks and unmuffled engine noise coming from the manifolds. The gaskets fixed the problem. I'm just not sure how a piece of what appears to be solid metal just comes out.
I've never seen the FelPro exhaust manifold gaskets fail that way. You'd have to remove the head to measure the exhaust manifold surface to determine if it was warpped. MAW just replace the exhaust manifold gaskets.
There really is no need to remove the head. Clamp or wedge a straight edge or flat, thick metal to the exhaust surface and shine a light from below. Check the areas with light shining through with feeler gauges. .
The chunk was near the back between the two rear most bolts. All the bolts are on tight, except the one farthest back which was kind of loose. Please help me to understand how overtorqued bolts leads to the gasket partially disintegrating. What am I missing?
By over-torquing, you warp the manifold flange, causing a leak on the inside of the manifold. The hot exhaust gasses will start to burn the gasket from the inside(regardless of gasket material), until it burns thru to the outside.
The new gasket finally came today and I got them changed out. Sadly I won't be able to post pictures of it because it broke apart when removing it. It was very well stuck on the head even though I used no bonding agent at all. It was super brittle too, in fact it was so brittle I could take the bigger chunks and break them into smaller chunks with my hand, which given that it was very solid when installed was quite surprising.
Based on what I saw I have a theory about what happened. There has been an issue i only recently was able to get fixed of the tip of the tail pipe being too low and striking the road when going up an incline (like entering a slanted driveway from the road). This happened a few times, which I think caused the rear most bolt to walk out somewhat, and with how brittle the gasket was the chunk just broke on its own. Then the exhaust gas just pushed it out.
I have a theory. It appears to be a series of installation errors.
Why didn't you develop an exhaust leak at the exhaust manifold to down pipe ? Why didn't all the exhaust manifold bolts "walk out" ? Why didn't you re-torque things after running the engine a few minutes and cooling down ?
B.) That one bolt walked because that was where the stress point was, the distribution of force isn't equal. There is a reason this happened on the passenger side and not the driver side which is still working fine.
matchek
Mar 19, 2015 03:25 PM
