Passenger side alt. bracket question
So on the passenger side alternator bracket what sets the tension on the lower ear of the alternator(the clearance hole ear)? Would it be a sleeve kinda like the later model gm stuff with the serpentine belt?
I'm asking because you drop the alternator in and when you tighten that lower bolt the alternator is still loose. So I guess what I was asking is the only thing that holds the alternator tight the 5/16 bolt on the top ear? So yes it's just the top bolt in the slotted bracket thank you.
