Passenger side alt. bracket question
Old Aug 15, 2021 | 06:36 PM
Hippi's Avatar
So on the passenger side alternator bracket what sets the tension on the lower ear of the alternator(the clearance hole ear)? Would it be a sleeve kinda like the later model gm stuff with the serpentine belt?
Old Aug 16, 2021 | 05:33 AM
I'm sorry, but I have no idea what you're talking about. The bottom ear of the alternator fits right into the bracket and a bolt goes all the way through. The bolt in the upper ear rides in the slot in the "Y" shaped bracket so you can adjust belt tension. There aren't any sleeves or anything. There's really nothing complex about it.
Old Aug 16, 2021 | 05:48 AM
Hippi's Avatar
I'm asking because you drop the alternator in and when you tighten that lower bolt the alternator is still loose. So I guess what I was asking is the only thing that holds the alternator tight the 5/16 bolt on the top ear? So yes it's just the top bolt in the slotted bracket thank you.
Old Aug 16, 2021 | 05:51 AM
The lower bolt is a pivot. The upper is the bolt that keeps tension on the belt.
Old Aug 16, 2021 | 05:59 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I had the opposite issue, the Summit Chrome 10 DN alternator was too big for the bracket. You could add washers or make up a spacer but as Joe said, not necessary.
Old Aug 16, 2021 | 06:19 AM
Just so we're clear, the stock alternator fits pretty tightly in the bottom bracket. If there's a lot of clearance, there's something wrong.
rocken
Jan 15, 2021 09:29 PM
Mr Nick
Jul 26, 2015 09:21 PM
68 D88
Feb 2, 2014 02:29 PM
HouTXCutlass
Jun 30, 2010 09:18 AM
cisco88
May 27, 2008 03:12 PM
