Olds 88 1960 misfiring problems
Old Jul 15, 2020 | 08:08 AM
Super88-60's Avatar
Hello, I’ve got a olds 88 with some major misfiring issues. Starts sometimes, but it runs really rough. If I give it a bit of gas it wont rev but missfires instead.
Ive replaced the carburator to a new one
I checked the timing chain so it lines up with the cam wheel (the two dots facing eachother) but cylinder one isnt in TDC when they match up
I’ve adjusted the point breaker to .5mm
Ive checked that every cylinder gets spark
Ive checked the compression on each cylinder
Ive set the timing so it at least should start
Idk really whats more to check or replace?
Hope some of u guys could help me out
Old Jul 15, 2020 | 08:22 AM
When the 2 dots are adjacent (crank at 12 and cam gear at 6) to each other #6 cylinder is firing. Oldsmobile distributor turns CCW.
Old Jul 15, 2020 | 08:33 AM
Super88-60's Avatar
Thanks, then I know they are right.
Old Jul 15, 2020 | 08:40 AM
Super88-60's Avatar
Is the firing order the same on all olds engines?
Old Jul 15, 2020 | 10:26 AM
I believe yours is 1-8-7-3-6-5-4-2 for 49-64 where as the later models are 1-8-4-3-6-5-7-2
Old Jul 15, 2020 | 11:06 AM
Super88-60's Avatar
I got it running! I turned the point breakers 45 degrees ccw and it runs pretty smooth, just needs a little fine tuning
Old Jul 15, 2020 | 12:37 PM
D. Yaros's Avatar
The specs for the Olds 394 engine say: "Turn adjusting screw in until engine
begins to misfire, then back screw 1/2
turn
You say you set the points at 5 mm. I am not a thoroughly conversant on the conversion, but I believe that comes out to nearly .020. You might get better results by narrowing the gap to .016 or 4 mm? Timing should be set at 5 degrees before TDC.
Old Jul 15, 2020 | 12:48 PM
Sugar Bear's Avatar
Adjusting the point gap changed the ignition timing. Set the point gap first and then the ignition timing. Also, triple check the firing order, it should be cast into the intake manifold.
Good luck!!!
Old Jul 15, 2020 | 01:38 PM
I don't understand this statement? But glad its running good now.
Old Jul 16, 2020 | 12:24 PM
rocketraider's Avatar
Oldsdruid
I've learned to look at a new poster's profile to see where they are and looks like he's in eastern Europe, which might explain his metric specs. 60, if you can find a dwell meter/tachometer it will make tuning your vehicle easier, especially since your car has externally adjustable points. Those have gotten hard to find in US so don't know about finding one on the Continent.
Old Jul 17, 2020 | 08:05 AM
Charlie Jones's Avatar
Phantom Phixer
They are all over E-Bay $20 and up ;
https://www.ebay.com/sch/i.html?_fro...963+oldsmobile
at3regency
Jul 12, 2015 06:08 PM
1970cutlasssupreme
Oct 4, 2013 10:29 AM
Matt Hohmann
Aug 14, 2013 09:54 AM
joepenoso
Jul 31, 2013 08:29 AM
crholds442
Dec 8, 2010 08:16 PM
