Help identify Quadrajet
Old Nov 26, 2019 | 04:37 PM
Dalemo's Avatar
I found a Quadrajet carb in the trunk of a car I bought and can’t figure out what its for, any help?
17083253
1173 FLC
thanks in advance!
Dale Moody
Old Nov 26, 2019 | 04:48 PM
Well, most of the time they get it correct - sometimes the information is a bit generic, but a fast Google search demonstrates it was employed 86-90 on Chev BOP 305/307.
https://www.carburetion.com/CarbNumb...umber=17083253
Old Nov 26, 2019 | 05:38 PM
This would apparently not be one of those times.
17083253 is for a 1983 Oldsmobile 307 with CCC only. The carbs on the Chevy 305 were similar but used a side inlet, not a front inlet. Chevy carbs of that vintage end in numbers like 206, 208, 210. The "1708" indicates the decade of the 1980s. The "3" indicates the specific year (1983). The "253" indicates the application (Oldsmobile 307 with CCC). The CCC carbs of the 1980s were similar but not identical nor even swappable from year-to-year. The big difference (aside from metering rods) is the two-point vs three-point adjustment on the mixture control solenoid armature.
Old Nov 26, 2019 | 05:41 PM
Indeed. Thanks, Joe.
Old Nov 29, 2019 | 01:54 PM
Dalemo's Avatar
Thank you
I appreciate the help, thanks a bunch!
Copper Nine Eight
Jul 7, 2017 04:41 AM
2blu442
Dec 30, 2013 03:53 PM
79Cutlass805
Jan 16, 2013 12:25 PM
84oldsDelta88
Oct 7, 2011 04:56 PM
83 delta 88
Jun 18, 2010 06:05 PM
