Have you ever seen a quadrajet built buy Carter?
Old Dec 27, 2013 | 07:02 PM
2blu442's Avatar
For years I've been collecting Quadrajet carbs at swap meets, many not Oldsmobile applications. I figure they can be used for parts if nothing else. When I was keying out applications I came across this one that kinda threw me for a loop!
Old Dec 27, 2013 | 07:14 PM
If I recall, in the late '60s Carter manufactured some carbs for Rochester under contract because Rochester was overwhelmed by the demand.
Old Dec 27, 2013 | 08:39 PM
BILL DEMMER's Avatar
Just the facts...
yes, many of them. they will have the model number info stamped-in upside down. often, you will find a C inside of a circle on many of the individual pieces. many don't have markings on the pri./sec. metering rods and the jets were not marked like rp's were-just a number stamp. typically, pontiac and chebby models were made by carter into the early 70's. as mentioned above, it was due to rp's inability to keep-up with production demands. with the advent of emission control systems, rp was chosen to make many of those pieces in addition to carburetors.
bill
Old Dec 27, 2013 | 08:42 PM
There are two kinds of Carter Quadrajets. If it has a Rochester number, it's a licensed one for a GM car like mentioned above. My 72 Monte Carlo has such a carb.
Carter later acquired rights to quadrajet design, and those will have the 4 digit Carter code, and those are aftermarket.
Old Dec 27, 2013 | 08:49 PM
costpenn's Avatar
I remember a friend of mine in high school who's Dad had a 71 429 Ford Mustang with a Q-jet on it. It is the only one of that weird GM Ford pairing, along with the 69 H/O flapper motor that I know of.
Old Dec 27, 2013 | 08:54 PM
2blu442's Avatar
Ah... my friends 1971 Cougar Convertible with the 429 CJ engine had a holly on it. But I'd read it should have been a quadrajet. That had me scratching my head but now I understand!
Thanks to all the comments. I now know more about this carb
John
Old Dec 28, 2013 | 04:55 AM
jensenracing77's Avatar
Greg at Sparky's carbs mentioned to me at one time that the Carter castings are much better than the Rochester.
Old Dec 28, 2013 | 07:04 AM
So I guess you've never seen the "Dearborn" HD toploader three speed used in 1965-69 A-body cars...
Old Dec 29, 2013 | 02:37 PM
Just the facts...
we've done a few of those, very funky indeed.
bill
Old Dec 29, 2013 | 05:16 PM
junkyardjeff's Avatar
I have only seen a couple.
Old Dec 29, 2013 | 05:55 PM
66 Olznut's Avatar
Ca's Only Official OLZNUT
Didn't Mopar use them in the late 70's or so also?
Old Dec 29, 2013 | 07:06 PM
Octania's Avatar
"Have you ever seen a quadrajet built buy Carter?"
Yes, I think I have ONE in the collection
Old Dec 30, 2013 | 09:53 AM
rocketraider's Avatar
Oldsdruid
I had a couple Pontiacs that came with Carter QJets. Never saw them on anything else. The Ford QJet application was weird but not unheard of. Sometimes it was cheaper for a carmaker to buy something another manufacturer had on the shelf than it was to R&D their own- that's how our Oldsmobiles ended up with the Dearborn top loader 3-speed. No more of those than Olds (or Pontiac) sold, cheaper to buy from Ford who had bazillions of them on the shelf than to try to get Saginaw or Muncie to build a suitable unit.
I don't remember QJets on Mopars. Most of those used Carter ThermoQuads, or as my Mopar friends are fond of calling them, Thermo-bogs.
Old Dec 30, 2013 | 03:53 PM
jag1886's Avatar
When I worked in a shop back in the 70's I saw a good number of Carter Qjets and there where a lot of Fords that had Qjets on them also.
2blu442
Nov 12, 2013 06:02 PM
GoodOldsGuyDougie
Nov 1, 2010 03:51 PM
lshlsh2
Sep 8, 2010 10:17 AM
442much
May 29, 2010 10:15 AM
Eddie Hansen
Ninety-Eight
Nov 5, 2009 12:24 PM
